Another good solution is to glue a layer of plastic laminate on your table top. This tends to last very well, can be marked with a pencil and easily cleaned. ShopNotes has a plan that uses 3/4" plywood with two layers of 1/4" hardboard on top. This is wrapped with hardwood and then covered with laminate on top and bottom to prevent warping. You will find other ideas for tops by browsing the forums.
