View Single Post
Old 06-23-2008, 11:20 AM   #1
henseman
New Member
henseman is on a distinguished road
Question horizontal router bits with backcutters
hi all,
I'm wondering if a horizontal raised panel bit with a back cutter can be used if you remove the back cutter.
I can't find any information from the manufacturer (Freud). I purchased a 3 pc. set that included a vertical ogee bit and realized I should have purchased the set with the horizontal raised panel bit. I went out and bought a bit with back cutter from Samona and found that it did not match the Freud rail & stile pattern especially the tongue thickness. It was less than 1/3d the cost of the freud bit and makes a horrible cut. Freud's quadra cut bits seem the way to go.
Thanks,
Brian
henseman is offline   Top - Reply with Quote
