| This is a discussion on Tool chest within the AxlMyks' stuff forums, part of the Member Galleries category; I started on the drawer faces. Using the book-matched pieces I had resawn and planed ... |
| | LinkBack (4) | Thread Tools | Display Modes |
| | #41 (permalink) | ||
| Forum Contributor ![]() |
I started on the drawer faces. Using the book-matched pieces I had resawn and planed earlier, I cut them to size. They will be glued to the front of the drawers when I get them done. ![]()
__________________ . Never, under any circumstances, combine a sleeping pill and a laxative on the same night. Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | ||
| | #42 (permalink) | ||
Now it's time for the drawer slides. This is the reason the case hasn't been glued together yet. You need to take the case apart to do this step. I started by using a 3/8" forstner bit to countersink the slide attachment holes. These will accomodate the #6X 1/2" flathead metal screws and small brass washers that attach the slides. You then drill a slightly oversize hole the rest of the way through. This allows for a small adjustment to the slides. ![]() ![]() Using the slide jigs made earlier, place a small piece of double sided tape to the ends of each runner, then put the runners in the jig. Now, slide the jigs and runners into the case and press them against the sides. Remove the jig and the slides are in position. ![]() ![]() Take the case apart and the sides will have the rails in place. ![]() Using a knife, score a line on the top of each rail so you can reattach them in the proper place. Drill pilot holes for the screws, remove the tape, and reattach the runners, using the scores as guides. ![]() Put the case back together, put the drawers in, and test for smooth operation. Adjust the slides as needed. ![]() When satisfied, you are ready to finally glue the carcase together.
| | #43 (permalink) | ||
Looking good Mike Where are you going to get your hardware from ?, brass or chrome ? Corner protects,handles,drawer pullers,locks,hinges,are you going to put locks in all the drawers or just a bar type the locks the drawers when the top is locked down ? or just a front cover over the drawers ? It's going to be nice PLEASE if you don't mind how much do you have in it...not counting the labor of love of making it..========
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #44 (permalink) | ||
Thanks Bj. Been a great project and has kept me out of trouble. ![]() I'm going to use brass hardware on it. The hinges are from ACO hardware, and I got the handles from HD today. Fold down type just like the ones I used on the cradle box. Still looking for the right drawer knobs. No corner protects are planned, and I'll be using 2 rods inside to lock the drawers. Then a mortise lock on the front. My first load of lumber was $140. That included 3 cherry boards, 1 curly maple, and 1 hard maple. Only used the cherry and had to buy some more of that. 8 or 10 poplar 1X3X6' and a couple 3X4X6'. I have a lot of scrap from this project. I probably have $225-$250 in it now. That doesn't count a few hundred in gasoline to get everything. That also doesn't count the new saw, 4 Freud blades, and the new planer. Otherwise it would total about $2,000.![]() One tip to anyone wanting to build something like this. I played holy heck trying to find 1/4" hardboard for the drawer bottoms. I finally settled on gluing 1/8" boards together because I could not find any 1/4". I tried every HD and Lowes around, and called every lumber store within a reasonable distance. So get that hardboard first, or decide to use something else. I glued the carcase together today, and did some tweaking of the drawers. Got the bottom screwed on, and am getting ready to edge the top and put the front panels on the drawers. That might not happen for a couple weeks. We're leaving for Pennsylvania Thursday morning for the weekend, then going to Washington D.C. for the most part of next week. Won't be back till Memorial day. So, one more picture till then.
__________________ . Never, under any circumstances, combine a sleeping pill and a laxative on the same night. Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ Last edited by AxlMyk; 05-13-2008 at 09:52 PM. | ||
| | #45 (permalink) | ||
| Forum Contributor ![]() Join Date: Sep 2004 Location: New Lebanon, Ohio "USA" First Name: Dave or "Doc" Posts: 8,700 ![]() |
Thanks for the pics Mike. Have a safe trip and enjoy.
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. ![]() Please Please Please edit your profile with a name and location so we can better assist you and make for a friendlier forum.![]() Thank you. | ||
| | #46 (permalink) | ||
| Registered User ![]() Join Date: Nov 2005 Location: Belgrave Ontario First Name: John Posts: 1,551 ![]() |
Great looking project Mike , i can,t wait to see it completed . | ||
| | #47 (permalink) | ||
I can't wait either John. It's getting near completion now. Some final sanding and tung oil. Found some time today to do some work on it. I had decided to rout around the drawer edges so the front wouldn't have such a blank stare look about it. Glued the panels to the drawers, and this is how it'll sit till I get home to finish it. I'm liking it more each day. ![]()
| | #48 (permalink) | ||
| Retired Moderator ![]() |
Hi Mike, It's coming along quite nicely. Tung oil eh? Ohhh, it's going to look very sweet. I can't wait!! ![]()
__________________ Ken ***Please fill in your profile, at least your location. As this will help us help you better.*** "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown | ||
| | #49 (permalink) | ||
Mike I was carving today and got some tools out of my HF chest and thought about your cherry chest and since I have been on the road for the last 2 weeks figured I missed a bunch. Man is that sweet looking. The cherry fronts look awesome. Matching the grain looks awesome. Nice job Mike. It's easy to see this was a ton of work but you have knocked it out. If you are going to be using pure tung oil, be prepared for some long drying time, it looks beautiful but stays tacky for a long time. Corey | ||
| | #50 (permalink) | ||
| Registered User ![]() |
Mike, that is a really nice tool chest, great work. | ||
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/axlmyks-stuff/7909-tool-chest.html | ||||
| Posted By | For | Type | Date | |
| Cherry tool chest - Fine Woodworking | This thread | Refback | 09-15-2009 09:28 AM | |
| Sawmill Creek - View Single Post - Cherry tool chest | This thread | Refback | 07-21-2009 10:34 PM | |
| Cherry tool chest - Fine Woodworking | This thread | Refback | 05-12-2009 05:33 PM | |
| Cherry tool chest - Sawmill Creek | This thread | Refback | 05-12-2009 02:11 PM | |
| Tool Review Guidelines ~ READ BEFORE POSTING | Mark | Tool Reviews | 1 | 01-21-2010 09:43 PM |
| Tool Chest Plan | ACV | Project Plans and How To | 12 | 10-04-2009 08:39 PM |
| Base for tool chest | AxlMyk | AxlMyks' stuff | 16 | 06-06-2008 11:12 AM |
| Tool chest pics | AxlMyk | AxlMyks' stuff | 17 | 06-05-2008 04:12 PM |
| Tool chest from Sony TV cabinet... | Joe Lyddon | Show N' Tell | 17 | 06-08-2007 08:23 PM |
