| | #1 |
| Marine Engineer Forum King | http://woodcraft.com/family.aspx?fam...lySpecial=True Saw this one today, thought it might interest one or two of you
| | #2 |
| Retired Moderator Supreme Forum King | Wow ,that is an awesome price for that router. Not sure but I think this is the same router BJ picked up somewhere else for that kind of money as well. Must be a new model coming. Corey |
| | #3 |
| Registered User Sr. Member | HartvilleTool.com has it for $125 with free shipping. I bought one there about a month ago for the same price. |
| | #4 |
| Registered User New Member | Hey guys, I'm brand new here. I just bought this router for use in a table. Anyone have this mounted in a table? Any tips on the best way to use it in a table? |
| | #5 |
| Official Greeter Supreme Forum King | Welcome to the forums Mike.
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. |
| | #6 |
| Registered User New Member | thanks Doc! |
| | #7 | |
| Registered User Forum King | Quote:
Best tip? Take the spring/s out of it for table use.
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | |
| | #8 | |
| Forum Contributer Supreme Forum King | Hi MikeWood I have one mounted in a table it's the 1700 model, it's a great router for the router table, the one you have is made to work in the router table right out of the box ,it can be adjusted from the top side of the table and because the model number you have they made the motor shaft longer so you can change the bit from the top side of the router table. The one I have I can do the same but I used a offset wrench that will let me do the same , plus you don't need to remove the springs from the Freud because it can be adjusted so easy from the top side.or the bottom side..one of the nice things about the Freud is that it's thiner than most routers that's a big help if you want to pop it out and used it for your plunge router with the nice big base plate on it...and the handles don't stick out as far as most routers do.. I just got one more or to say I should have it in a week .. ![]() I also have a Hitachi 3 1/4 HP and It can't have the handles in place because they stick out to far to get it in the 11" sq. hole in the table top... As far for the tips you don't need them so to speak it's a great router,one small tip you don't need push router at it's high speed, I run mine at the number one or the number two setting most of the time it has all the power you will need at the low speeds,,,... ============ Quote:
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Last edited by bobj3; 12-01-2007 at 07:38 PM. | |
| | #9 |
| Registered User New Member | Thank Bj....unfortunately, for some reason there was no owners manual in the box when I got the router today, so I'm figuring this out on my own. I don't see how the shaft is long enough to change bits above the table? But maybe I just haven't figured it out yet. Mike |
| | #10 |
| Forum Contributer Supreme Forum King | Hi Mike You may want to drop Charles M. a PM ,I'm sure he can get you one (Manual) It's not that great of a manual but it's nice to have for the pars list just in case.. http://www.routerforums.com/members/charles-m-7718.html http://www.routerforums.com/private.php?do=newpm&u=7718 Do you have the router mounted to a drop in base plate in the router table ? ===========
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html |
| Delta Model 40-680 20" Scroll Saw. | rstermer | Wood Scrolling | 7 | 05-29-2008 07:46 AM |
| Ship Model | densships | Show N' Tell | 19 | 05-10-2008 05:58 PM |
| model 315 17351 = model 735-2 | mjmpropman | General Routing | 2 | 04-28-2008 02:13 AM |
| Router model recomendation | pinto1148 | General Routing | 10 | 03-07-2008 08:45 AM |
| craftsman router model #26620 | hshumsky | Starting Off | 2 | 01-11-2008 01:58 PM |
