The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Go Back   Router Forums > General Woodworking > Tools and Woodworking > The Bargain Bin
Reload this Page Bench-top Drill Press
The Bargain Bin Discuss Bench-top Drill Press in the Tools and Woodworking forums; Any opinions on which bench-top drill presses are useful? I'm not looking for a heavy-duty production tool, ...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 12-30-2007, 05:47 AM   #1
Thrifty Tool Guy
Sr. Member
User Info
Trader Rating: (0)
Gallery: View
Thrifty Tool Guy is on a distinguished road
Default Bench-top Drill Press
Send Private Message | View Profile
Any opinions on which bench-top drill presses are useful? I'm not looking for a heavy-duty production tool, just something to spin my Forstner bits in a reasonably accurate manner.
Thrifty Tool Guy is offline   Top | Reply with Quote |
Sponsors
You currently aren't registered, click here to register.
Old 12-30-2007, 06:43 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
Hi Thrifty Tool Guy
I recommend the one below
http://www.routerforums.com/tools-w...rill-press.html
But some of the HF models are good also.
http://www.harborfreight.com/cpi/ct...temnumber=44836
http://search.harborfreight.com/cpi...press&Submit=Go
Workshop Projects
Router Tables plans FREE, plus more
http://www.absolutelyfreeplans.com/...op_projects.htm
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
bobj3 is offline   Top | Reply with Quote |
Old 12-30-2007, 08:40 AM   #3
challagan
Supreme Forum King
challagan's Avatar
User Info
Trader Rating: (0)
Gallery: View
Country: USA
challagan is on a distinguished road
Hello, I like the one Bob has as well and wish I had that one for the money but I do have a review of about 10 different models from Fine Woodworking. The top three models that they tested all had 3/4 HP motors ... 2 tied for best overall
General Intl 75-100 - a real work house with an excellent motor, ease of speed change and the least amount of runnout of all units tested. The down side is $450.
Tied for best overall was the Jet JDP 15M and has good 3/4 HP motor and nearly identical numbers accross the board and has the biggest table of all tested AND ... $100.00 Cheaper than the General
Best VAlue - Grizzly G7943 - scored in the top three for drilling power with there 3/4 HP and offers the slowest of speed settings and it's price tag - $ 225.00
Hope this helps a bit.
My Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top | Reply with Quote |
Old 12-30-2007, 10:15 AM   #4
Hamlin
Supreme Forum King
User Info
Trader Rating: (0)
Gallery: View
Country: Kansas - USA
Ken
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Hamlin is offline   Top | Reply with Quote |
Old 12-30-2007, 11:21 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
User Info
Trader Rating: (1)
Gallery: View
Country: USA
Talking about Floor Model Drill Press, you can make your Bench Model into a floor model quick and easy.
Because in most work shops the bench top is at a premium, all you need to do is pickup a 2 " to 2 1/2" steel pipe with threads on both ends and then pickup 2 ea.threaded flanges that screw on the ends of the pipe...with just little black paint and 3 or 4 bolts and nuts you have a floor model that will fit any where in the shop...
The pipe and flanges can be had at just about any plumping outlet supply outlet for about 25.oo bucks, if you go this way besure to trace the flange you now have so the bolts can line up with the new flanges...most have 3 to 4 holes for mounting...you may need to drill the holes in the new flanges but that's no big deal because you have a drill press that can do that easy...
Also drill and tap a hole in the flanges for a Allen set screw to lock it in place...once you have it setup... ( 1/4-20 x 1/4" Allen set screw)
Workshop Projects
Old 12-30-2007, 01:01 PM   #6
vapochilled
Forum Fanatic
User Info
Trader Rating: (0)
Gallery: View
vapochilled is on a distinguished road
I know people will laugh and shun me as the woodworking social outcast I am, But.
I picked up a benchtop drill at HF, $79 of course is does not run as true as anything decent, but as yet, when I put the point of a bit where I want it, it has not drilled a larger hole than planed.
5 speeds, 3/4 chuck, so far it has done everything asked of it.
vapochilled is offline   Top | Reply with Quote |
Old 01-02-2008, 03:20 PM   #7
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
User Info
Trader Rating: (0)
Gallery: View
Drugstore Cowboy is on a distinguished road
Originally Posted by vapochilled
. . . but as yet, when I put the point of a bit where I want it, it has not drilled a larger hole than planed. . . .
I've noticed that over the years too
Oddly enough -- a 3' oak table leg -- measures out at the same 3' whether I cut it with my $15 hand saw or my $40 Craftsman circular or my $90 Delta benchtop --- or my neighbors $500 contractors table saw.
As for drill presses -- I just bought my first - for $50 (Thankgiving Sale) at Ace Hardware.
It's only 8" with a 1/2" chuck. I may well find things I want it to do that it cant -- but for now -- like you said -- it puts a hole the size of the bit right where I ask it to. So -- I'm content.
The one who says it can't be done --
Should avoid interrupting
the person doing it.
Drugstore Cowboy is offline   Top | Reply with Quote |
Old 01-02-2008, 03:45 PM   #8
reikimaster
Forum Geek
User Info
Trader Rating: (0)
Gallery: View
reikimaster is on a distinguished road
My benchtop DP is from a fire department tool sale. Kinda like one of those traveling carnivals But as you said... it works. It's cast, not stamped, and it's heavy. The motor runs smooth and quiet. The shaft turns true and it has 5 speeds and a big chuck.
I would LOVE to have a better one.... but.... what's "better" if what I have works? I guess I'll have to wait until I need more out of a drill press before I find what's better.
On the other hand.... buying inexpensive tools is usually a crap shoot and I rolled craps more times than I care to admit. I TRY to buy the best I can afford, but I also believe it's possible to OVER-buy. Why spend $1600 on a saw if the $600 one will do everything you need (and do it well)? Then you have $1000 to spend on something else. If I get to a point where having that $1600 table saw is a necessity, then I'll get it.
As I always tell my wife... I may be easy, but I ain't cheap!
reikimaster is offline   Top | Reply with Quote |
Old 03-14-2008, 05:37 PM   #9
Thrifty Tool Guy
Sr. Member
User Info
Trader Rating: (0)
Gallery: View
Well, a half-price sale at Lowes on the B&D Firestorm drill press was too much for me to resist. Factoring in a $10 off coupon on purchases of $50+, I can claim that I purchased a 10" DP for $39.50 . That is less than I paid for 11lbs of dry cat food (important spouse negotiating point). It went together fairly quickly and spins a 1" forstner bit OK. There's some wobble, but I think I can cure that with correctly seating the chuck on the tapered shaft. If I need more power than the 3.2A motor, there's always the option of a new motor from Grizzly.
Old 03-14-2008, 05:44 PM   #10
Hamlin
Supreme Forum King
User Info
Trader Rating: (0)
Gallery: View
Congrats TTG. Sounds like a good deal.
Ken
"A VETERAN"
Search this Thread:
Advanced Search
New Drill Press bobj3 Tools and Woodworking 27 08-02-2007 10:11 PM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 7 07-15-2006 11:20 AM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 3 03-25-2006 10:43 PM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 09:07 PM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 09:03 PM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
