Dust shoe reboot (no pun intended) - Router Forums
 25Likes
post #1 of 22 (permalink) Old 12-20-2016, 10:17 AM Thread Starter
difalkner's Avatar
First Name: David
Default Dust shoe reboot (no pun intended)
I made an MDF dust shoe a few weeks ago and thought I'd make another one to try some different things on for size (sorry, another 'shoe' reference... ugh!). The first thing I did was to make the holes the correct size. On the first one I made the spindle hole 4" dia. when in fact it is 100mm (3.93"). That meant I had to do some makeshift shimming and it was only holding so-so and I wanted a better fit. The second thing I did is to label the sides 'Dust' and 'No Dust' so the dust and chips will know which side is which...
This is as far as I got on the little project - more later. Ultimately I want to make one out of Acrylic or Plexiglas but right now MDF will suffice.
kp91, chessnut2, DaninVan and 7 others like this.
David
Nothing to do with woodworking at all, just our music at church (I'm the guy with the Koa Takamine) - Airline Baptist Church BC Songs
Romans 3:23
difalkner is offline
post #2 of 22 (permalink) Old 12-20-2016, 11:03 AM
First Name: 4D
Looks good David. Love the labels!
I do have serious reservations about how long the MDF will survive, mainly at the tightening points. A version done in 1/2" aluminum or a good acrylic/HDPE/whatever plastic might do better in the same configuration. Keep us updated on how well it works, and if the dust behaves better thanks to carved instructions.
4D
4DThinker is offline
post #3 of 22 (permalink) Old 12-20-2016, 06:02 PM Thread Starter
difalkner's Avatar
First Name: David
Well, first testing shows that it followed directions perfectly - there are no chips or dust on top...
Now I'll see what I can do about getting a brush or clear shield to contain the dust and chips even though Walnut is such an awesome wood even in chip form.
David
Romans 3:23
post #4 of 22 (permalink) Old 12-31-2016, 10:22 PM Thread Starter
difalkner's Avatar
First Name: David
Here's an update on the dust shoe but I had to upload it as a wmv instead of my normal mp4 so the video quality isn't quite as good as my normal high-quality cutting edge videos...
Chris Hachet likes this.
David
Romans 3:23
post #5 of 22 (permalink) Old 12-31-2016, 11:11 PM
RainMan 2.0's Avatar
I liked the fact that it was clear and you could see inside , but I thought it was rubber , not a tupaware bowl lol .
Good try though.
This is the stuff I thought it was . Wonder how much it costs ?
http://www.silex.co.uk/products/sili...ilicone-sheet/
difalkner and Scottart like this.
I don't actaully know anything about CNC router tables , but I stayed at a Holiday Inn Express last night
RainMan 2.0 is online now
post #6 of 22 (permalink) Old 01-01-2017, 07:39 AM Thread Starter
difalkner's Avatar
First Name: David
That's more like I wanted, Rick, but it seems you have to buy so much of it that it becomes prohibitive for what little I'll use. My 'bowl' certainly didn't work!! LOL!
David
Romans 3:23
post #7 of 22 (permalink) Old 01-01-2017, 08:20 AM
Dave,
You can buy just the brush part from, I think McMaster and a couple other places. Then you fit it to your piece. Should be fairly cheap.
HJ
difalkner likes this.
honesttjohn is offline
post #8 of 22 (permalink) Old 01-03-2017, 11:07 AM
SteveMI's Avatar
First Name: Steve
I have used these, Easy-Cut Strip Brush, 1/4" Wide x 3/16" High Backing, 3" Overall Height - https://www.mcmaster.com/#conveyor-brushes/=15r3gm6 $4.39 per foot.
One consideration is the stiffness. If mounted true vertical, any dust screen will add Z axis resistance. Softer or more pliable the better. When I put the short 1" easy-cut conveyor brushes on mine the added resistance really was significant. Since then I angle them out about 10 degrees. I bought 3 feet of 1", 2" and 3" to evaluate and am now just using the 3".
In the near future, in my next order from McMaster Carr, I will probably try the soft horsehair brushes - Galvanized Steel-Backed Conveyor Strip Brush, Horsehair Bristles, 3/16" Wide x 7/32" High Back, 3" Overall Height - https://www.mcmaster.com/#conveyor-brushes/=15r3k0q Of course they are more than double the cost at $9.58 per foot, but dust foot doesn't take much.
Neither of these lets you see the cutting going on.
Steve.
SteveMI is offline
post #9 of 22 (permalink) Old 01-04-2017, 09:46 AM
bgriggs's Avatar
I used a similar design years ago. You have to curl the ends up to make it work. In fact I ended up with a "J" shape at the base of the fingers.
Bill
SteveMI and difalkner like this.
Making the world a better place, one project at a time. CNC Router, Aspire, Cut3D, PhotoVcarve, Alibre, Rhino, Laser cutter, foam cutter.
bgriggs is offline
post #10 of 22 (permalink) Old 01-04-2017, 10:08 AM Thread Starter
difalkner's Avatar
First Name: David
That's very close to the one I did, Bill, very close. Did the sharp edges scratch softer woods? I definitely like being able to see the cutter as it works.
David
Romans 3:23
Human Verification
Tips for Installing a Dust Collection System Router Forums Featured Topics 121 02-24-2017 11:20 AM
Small shop dust collection Barry747 Shop Safety 4 10-12-2015 11:04 AM
Making the plunge into CNC, no pun intended. blurrycustoms CNC Routing 1 03-25-2009 08:16 AM
Turning to the lathe... pun intended Mike Woodturning and Lathes 25 12-30-2007 09:33 AM
Neat bit (no pun intended) of info kp91 Router Bits - Types and Usage 2 10-18-2007 06:46 PM
