end mills for cutting 2 inch stock - Router Forums
 8Likes
post #1 of 12 (permalink) Old 04-16-2017, 08:06 AM Thread Starter
kp91's Avatar
First Name: Doug
Default end mills for cutting 2 inch stock
Happy Easter everyone!
Has any one found a good 1/4 inch spiral bit for cutting through 2 inch stock? I don't know if such a monster exists, or if I have to go up to a larger diameter.
If anyone can recommend a favorite, I would be most appreciative!
I have tried a google search but everything pretty much tops out at 2-1/2 inch overall length, which doesn't give me much to grab in the collet.
Its out there, I am sure, I just can't find it because I am looking too hard.
1 John 1:9
Fredericksburg, VA
My daughter amazes me https://houndsathazelwild.wordpress....houndgold2016/
kp91 is offline
post #2 of 12 (permalink) Old 04-16-2017, 09:06 AM
bgriggs's Avatar
American Carbide sells long bits but I don't think you will find a 1/4" bit that will cut 2". Square End Uncoated & Coated
Bill
kp91 likes this.
Making the world a better place, one project at a time. CNC Router, Aspire, Cut3D, PhotoVcarve, Alibre, Rhino, Laser cutter, foam cutter.
bgriggs is offline
post #3 of 12 (permalink) Old 04-16-2017, 09:25 AM
First Name: 4D
When I run into a need to cut thicker material than I have a bit for, I let the bit cut as deep as it can, then simply band saw the part out being careful not to let the blade touch the finished edge. Then I use a flush trim bit on a router table to mill off the bottom protruding edge. If the part is a hole and can't be cut free using a band saw, I use a jigsaw.
4D
kp91 likes this.
4DThinker is offline
post #4 of 12 (permalink) Old 04-16-2017, 09:46 AM
Nickp's Avatar
First Name: Nick
How about...drill the end limits all the way through on drill press...attack from both sides...
...real solution would be to get a "compression" bit in 1/2" shaft, appropriate length...pricey but like a torque wrench, ya gotta have it when ya need it.
The compression bit leaves clean edges on both sides of the slot...
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is offline
post #5 of 12 (permalink) Old 04-16-2017, 10:47 AM
Doug even if you could find one that long I don't think it would do a good job, or last very long. There would be too much chatter and vibration with a bit that small and that long. Even a 1/2" at 2 inches starts to chatter a bit.
post #6 of 12 (permalink) Old 04-16-2017, 11:36 AM
Doug,what kind of wood you cutting,and is it a blind hole like a mortise, or cutting out a shape? A CNC?
Herb Stoops is online now
post #7 of 12 (permalink) Old 04-16-2017, 12:04 PM
post #8 of 12 (permalink) Old 04-16-2017, 06:56 PM
Precisebits.com or as it is also known ThinkandTinker .com. Get hold of Ron Reed -- he's got the longer bits.
kp91 likes this.
HJ
Detroit Burbs
honesttjohn is offline
post #9 of 12 (permalink) Old 04-16-2017, 07:52 PM Thread Starter
kp91's Avatar
First Name: Doug
I would only use it for the last 1/4 inch. I cut the pieces free with the bandsaw and trimmed on the router table, thought I might try one just a little bit longer and see the result.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #10 of 12 (permalink) Old 04-17-2017, 06:26 AM
difalkner's Avatar
First Name: David
4D
That's what I've been doing and it works for me. I have yet to look for a longer bit, though.
David
kp91 and Scottart like this.
David
Nothing to do with woodworking at all, just our music at church (I'm the guy with the Koa Takamine) - Airline Baptist Church BC Songs
Romans 3:23
difalkner is offline
Human Verification
Drop Leaf Rule Joint Using 1.5 Inch Stock TallFred Portable Routing 6 10-04-2012 05:51 AM
Need Jig for Dovetailing stock + Rockler woes + Katie? JavaGeek Jigs and Fixtures 16 02-17-2011 01:46 PM
Thin stock to 1/8 inch on Planer ACV Tools and Woodworking 6 10-21-2007 11:13 PM
mortises for 2 inch stock joe carter Jigs and Fixtures 2 05-30-2005 07:22 AM
