Help
Go Back   Router Forums > Routers > CNC Routing
Full 5 axes routing. 3 D ?
This is a discussion on Full 5 axes routing. 3 D ? within the CNC Routing forums, part of the Routers category; An EDM is a machine that uses a brass wire to cut metal. it create ...
Old 05-01-2009, 04:31 PM   #11 (permalink)
davidbarr's Avatar
First Name: David
davidbarr is on a distinguished road
Report Post Report This Post!
An EDM is a machine that uses a brass wire to cut metal. it create an electrical arc that cuts metal. it is used to make dies. Usually after they have already been hardened.
davidbarr is offline
Old 05-02-2009, 02:08 AM   #12 (permalink)
Dr.Zook's Avatar
First Name: Dave or "Doc"
Dr.Zook will become famous soon enough
Send a message via Skype™ to Dr.Zook
Cool Edm
Originally Posted by harrysin View Post
Pray what is an EDM machine and what is it used for?
Harry, EDM = Electrical Discharge Machining. Like David says, it is brass wire (about .020") run off a spool, down thru a set of upper and lower guides (kinda like a bandsaw) with voltage running thru the wire. Water is fed on the wire where it starts into the metal. If you are wire burning out a section of solid steel, you have a starter hole drilled thru the metal. You feed the wire down thru the upper gide, down thru the hole, then into the lower guide. The wire is then drawn thru the piece and runs into a waste container. Once the wire is used, it is scarp not to be used again. The newer machines are computer controled. The older machines ran off of tape. The upper giude and lower guide move independently of each other. Therefore, the square on one end and a circle on the other. It is an amasing machine. I have a sample where it has a number one on one end and a number two on the other.
Dave
the "Doctor"
Please Please Please edit your profile with a name and location so we can better assist you and make for a friendlier forum.
Thank you.
Dr.Zook is offline
Old 05-02-2009, 09:31 AM   #13 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
Thanks for those explanations but can such a machine really get anywhere close to 0.00002"?
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 05-02-2009, 11:09 AM   #14 (permalink)
davidbarr's Avatar
First Name: David
Higher end machines may. We have a cmm at work. It is a special cnc that uses a probe to inspect parts. When the guy was there calibrating it I asked him how accurate they were he told me they would check consistantly to 0.0002". They are the most accurate way to measure I have seen. So if the machine could hold that tollerance which I'm not sayin it can't. I wonder how you you could check it?
Old 05-03-2009, 07:40 AM   #15 (permalink)
harrysin's Avatar
I wouldn't have thought that a spark erosion cutter was capable of producing a smooth surface any more than a laser cutter can (can not)!
Harry
harrysin is offline
Old 05-03-2009, 01:48 PM   #16 (permalink)
xplorx4's Avatar
First Name: Jerry
xplorx4 is on a distinguished road
.0002?? Thats' about the thickness of a cell in a tree!! I was trying to decide the other day if it was 1/32" or 1/64" that I was cutting!! I guess I will have to join the micron caliper stuff. Just give me some time, and I will have one of those digital calipers "thingies" so I can get down to at least 0.002, lets see how much do I allow for the glue?
Lamentations 3:22-23
xplorx4 is offline
Old 05-04-2009, 10:04 AM   #17 (permalink)
harrysin's Avatar
Jerry, the gentleman claimed 0.00002", that's FOUR zeros. I have a dial gauge with 2 micron divisions which I used when replacing video head discs in Sony and Toshiba Beta VCR's, regrettably I haven't found a use for it since Beta machines went the way of the Dodo!
Harry
harrysin is offline
Old 05-04-2009, 06:40 PM   #18 (permalink)
davidbarr's Avatar
First Name: David
I know that this is a woodworking forum. But just to give you an idea what an EDM does. This is a car I made for my boy in Vo Tech.
No man e'er was glorious, who was not laborious.
Benjamin Franklin
I have no special talents. I am only passionately curious.
Albert Einstein
A wise monkey never monkeys with another monkey's monkey.
My Old Man
Boy I don't owe you nothin but a butt whoppin and that bill is long overdue!!!
There again My Old Man
Old 05-05-2009, 09:01 AM   #19 (permalink)
harrysin's Avatar
Thanks for that David, could you post an edge shot, also couldn't that sort of item be made as well by laser or high pressure water? I'm just curious, that's how I learn!
Harry
harrysin is offline
Old 05-05-2009, 06:31 PM   #20 (permalink)
davidbarr's Avatar
First Name: David
This is the best pic that i could get. the metal is pretty thin. Only 0.070" thats 1.778 mm to you Aussies. You are right about the laser and the water jet. They would do just as good a job and do it a lot faster. This took me a few hours to make on the EDM while it would have only took me a few minutes on the other machines. We had a EDM at school it was free to use, I was bored. It would not be very cost effective to make. An example on how to use it proper. We were building a die at work. The die required that a large block had to be machined with a large portion of its middle removed along with most of one outer edge. If we were to machine it then harden it the heat would cause the piece to warp. So we machined as much we could, heat treated it, and had the EDM remove the rest. The EDM was the best choice for that operation for two reasons. 1. the block was pretty thick, close to 2" or 50.8mm thick. (we have a laser at work and at that thickness the EDM produces a much better finnish) 2. You get absolutley no heat transfer with an EDM.
Benjamin Franklin
Albert Einstein
My Old Man
Routing Template Verlin Garrett Jigs and Fixtures 7 08-18-2009 07:11 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
Routing with Template Tom template tom Guide Bushings and Templates 82 04-14-2009 02:25 AM
Freehand routing Visteonguy General Routing 50 09-08-2008 12:26 AM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
