| This is a discussion on Full 5 axes routing. 3 D ? within the CNC Routing forums, part of the Routers category; I have a 5 axes EDM that I am going to do something with in ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I have a 5 axes EDM that I am going to do something with in the next few days. | ||
| | #2 (permalink) | ||
It is full 5 axes. UVXYZ. I was thinkin. Take all the wire guide assy. off. Add abracket to mount a router head for all xyz moves then rerun the programs with the spindle turned 90 deg. . This machine will run the XYZ EZ. But do yall think the UV would take it to the 3rd? The machine is very high tollerence. It will hold .00002". So Im thinkin this thing will sculpt? Anyone? Thanks Jim | ||
| | #3 (permalink) | ||
So you know. The place for the UV axes is to tilt the the wire in the Z axes. Which creates angles to the XY. holding .00002". Im gonna figure something out. Or junk it! Have fun Jim | ||
| | #4 (permalink) | ||
to explain. This machine will cut a circle at the top while cuttting a square in the bottom of the same part that is 10" thick. It is fully 5 axes. I think it will work. .....Ok you brains. I think it is all there except the Z negitive cuts. Ok so shoot it down? I see chips.. lol Jim Have fun, | ||
| | #5 (permalink) | ||
| Forum Contributor ![]() |
Hurry and get ten posts in so that you can post some photographs and an explanation of just what the machine was designed for, 0.00002" is a VERY close tolerance, probably closer than required for printed circuit board design.
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ | ||
| | #6 (permalink) | ||
HI WOW .0.00002" anything can be done now days but making the control room/box will be the challenge ,if you breath/blow on it ,out of torrence ..if it's not in a control room. ======
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Bob J. | ||
| | #7 (permalink) | ||
.0.00002" ??? I think there are too many zeros here
__________________ Nicolas | ||
| | #8 (permalink) | ||
Yes. That is 20 millionths. Hardly woodworking machinery. We require much greater tolerances.
__________________ . Never, under any circumstances, combine a sleeping pill and a laxative on the same night. Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | ||
| | #9 (permalink) | ||
No the #s are right. Its an EDM machine. | ||
| | #10 (permalink) | ||
Pray what is an EDM machine and what is it used for?
| Routing Template | Verlin Garrett | Jigs and Fixtures | 7 | 08-18-2009 08:11 AM |
| Router table or Plunge routing | template tom | Guide Bushings and Templates | 15 | 04-14-2009 03:45 AM |
| Routing with Template Tom | template tom | Guide Bushings and Templates | 82 | 04-14-2009 03:25 AM |
| Freehand routing | Visteonguy | General Routing | 50 | 09-08-2008 01:26 AM |
| Routing end grain | Pop_pop1 | Table-mounted Routing | 8 | 09-22-2004 01:24 PM |
