Help in cutting lexan - Router Forums
post #1 of 3 (permalink) Old 03-05-2011, 09:17 AM Thread Starter
Default Help in cutting lexan
CUTTING AND ENGRAVING LEXAN ON MY CNC WOULD LIKE TO KNOW WHAT BITS TO USE AND RPMS AND FEED SPEEDS
I HAVE A TECHNO 4896 LS ROUTER SOFTWARE ENROUTE4
David Sr is offline
post #2 of 3 (permalink) Old 03-06-2011, 01:38 PM
Phil P's Avatar
First Name: Phil
Take a look at the technical articles on the Onsrud Cutters site where there are several useful articles on machining plastics. These will form a good starting point for you to work from. The end solution will depend on what you find suits your machine and the material. Without knowing the complexity of the cut, thickness of material, etc it is impossible juts to give a one size fits all answer to your question
Regards
Phil
Phil P is offline
post #3 of 3 (permalink) Old 03-12-2011, 07:23 AM
Phil gave you "quality" directions! I have been a sign carver / ingraver for too many years. Most of it by hand, just got into CNC, and each time I start a new to project I try a sample with the material and bit(s) I will be using. Just remember with any type of plastics "heat" is what you don't want, high rpm / high feed rate or low rpm / low feed rate.
peg-legs is offline
Human Verification
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 08:35 AM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 10:42 PM
Cutting Lexan and Adpro Tubing tskaff Introductions 4 06-29-2010 12:36 AM
Cutting Lexan fibertech Jigs and Fixtures 1 06-24-2008 07:16 PM
cutting lexan rich1 Table-mounted Routing 7 03-23-2008 10:17 AM
