Go Back   Router Forums > Routers > CNC Routing
Rate This Thread - Router bit and Router size for CNC?.
Thread Tools Display Modes
Old 04-05-2007, 09:04 PM   #1
macg
Jr. Member
macg is on a distinguished road
Default Router bit and Router size ?
I want to cut some grooves with a 3/4" ball nose in MDF can anyone recommend the size router I need and what cutter size to get, I am planning to build a cnc from MDF and the plans call for this size, see rockcliffmachine com the grooves are for bearings, the plans say to use a table router or table saw to cut the grooves, I do not own a table router and want to buy one for other projects too.
macg is offline   Top - Reply with Quote
Old 04-05-2007, 09:20 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
At the top of our home page you will find a link to Oak Park, the home of The Router Workshop. You can purchase one of the best tables available there. You should have a router with a 1/2" collet, for help in choosing a router click on the blogs link and select Sawdust Dreams. You will find a wealth of good common sense information there to help you along. To cut a 3/4" groove you need a bit with a 3/4" diameter. Usually people would use a straight or plunge bit for this process, not a ball cutter. Is there a special reason you want to use the ball cutter bit?
Old 04-05-2007, 09:25 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi macq
Looks like you will need two ,3/4" and 1" If I readed the PDF file right.
Core Box Bits
#8718 3/4"
#8719 1"
http://www.mlcswoodworking.com/shops...s/bt_core.html
Bull Nose bits
#7764 3/4"
#7765 1"
http://www.mlcswoodworking.com/shops...s/bt_bull.html
Bj
Bj
Old 04-05-2007, 09:45 PM   #4
macg
Jr. Member
Thanks for the fast reply
I am trying to build this see a picture rockcliffmachine com it's a CNC router made from MDF or wood the bearing grooves call for grooves to be cut in the table slides for a 3/4" diameter bearing it can be a round, a vee or a straight groove I thought the round grooves would fit better. I cannot seem to insert a picture or link to this post
Old 04-05-2007, 10:15 PM   #5
macg
Jr. Member
I looked at Oak Park but I cannot find the 3/4" ball nose bit, is it available ?
Old 04-05-2007, 10:15 PM   #6
Senior Moderator
Supreme Forum King
You are not allowed to post links until after you have made 10 postings, this is to prevent spammers and such from posting junk. It would be best to cut a straight groove.
Old 04-05-2007, 10:19 PM   #7
macg
Jr. Member
I was hoping I could use a smaller trim router to cut the grooves, then I could use the same router and mount it in the cnc machine , is it possible to get a 3/4" straight bit with a 1/4" shank and if possible would a smaller router be able to cut these grooves in mdf?
Old 04-05-2007, 10:38 PM   #8
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
macg,
W e l c o m e . . A b o a r d !!
Joe Lyddon is offline   Top - Reply with Quote
Old 04-05-2007, 10:46 PM   #9
macg
Jr. Member
yes the core box bit looks good #6418 , I have been looking for a ball nose all this time, why is it called a core box bit? the plans call for the 3/4" dia. grooves to be cut 3/8" deep, it might be slow going with a smaller 1/4" collet router, but if I can do it I will be able to mount the router in the CNC machine I am building
Old 04-05-2007, 11:11 PM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
core box=
The most important part of a thing; the essence.
The portion of a mold which shapes the interior of a cylinder, tube, or other hollow casting, or which makes a hole in or through a casting; a part of the mold, made separate from and inserted in it, for shaping some part of the casting, the form of which is not determined by that of the pattern.
The center or inner part, as of an open space; as, the core of a square.
A projecting piece on a pattern which forms, in the mold, an impression for holding in place or steadying a core.
Bj
Bj
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
