| CNC Routing A place to discuss CarveWright, CompuCarve and other CNC routing devices. |
| | #11 | |
| Banned Supreme Forum King | Quote:
That was Fantastic! Thank you very much! Yes, I can see how it would do a wonderful job in making Patterns, knobs, & etc. limited only by one's imagination. Your last demo apparently used a 1/4" straight bit! Perfect for the "knob" job. So, your software, I guess, is flexible enough to be told Bit parameters... If a bit change were desired, would it stop to allow you to change bits, then continue once you gave the GO signal? The Table / Sled / Bed, or whatever you call it, looks very rugged and strong! Are the blue parts, ends, etc., a different kind of metal? Does the sled move on free rolling Rollers but controlled with cables? What is the main way the movements are controlled? That is so COOL!! I couild sit for hours & "pick your brain"!! So, I couldn't possibly type posts to do the same thing! ![]() Can you give us a Link to the Forum(s) that you used to get help as well as any other helpful Links? What are the sources data types from which you can work? For your sign; jpg or graphic pic? Mech. drawing, CADCAM software? Does your software use the machine to determine wood thickness or do you explicitly tell it? If you wanted, could you change bits in the Knob Job to Roundover the outside edges? How much do you leave uncut, at the bottom, to keep pieces in place? I could go on & on... So, I'll stop now... ![]() Thank you so much for sharing such a wonderful project!! We look forward to more from you... | |
| | #12 |
| Registered User Forum Fanatic | You guys are like I was when I first got started - inquisitive and excited about the machine. I hope I have answered all of your questions. If you have any more let me know and I will try my best to answer them. (1) PLEASE tell me it didn't cost an arm and a leg to make A. I probably have @$1000 in the machine and another $600 in the software. You can use the same software I do free but what it does is limited. (2) Was the one straight cutter used for all three operations and am I right in thinking that the cutter didn't go all the way through to prevent the knobs breaking free and hitting the cutter. A. Yes it was one cutter. If you look at the video closely, on the last pass, you can see the machine picking the router bit up just a small amount. With this software, I can put as many tabs as I want to around the item to hold it in place. After I am through cutting out the piece, I have to use a small screwdriver to pop the knob (or whatever) out of the wood. Then sand the tab off. (3) Your last demo apparently used a 1/4" straight bit! Perfect for the "knob" job. So, your software, I guess, is flexible enough to be told Bit parameters... If a bit change were desired, would it stop to allow you to change bits, then continue once you gave the GO signal? A. Yes the machine will stop to change bits. One of my future upgrades I am planning is to add a tool changer to the CNC. With this tool changer, the CNC will automatically go to the tool changer, drop off the router bit you just got through with, and then pick up the next bit that will be needed. All automatically.. You can see some videos of this at work: http://video.google.com/videoplay?do...11940888627972 http://video.google.com/videoplay?do...45240137833037 http://video.google.com/videoplay?do...91859906584476 (4) The Table / Sled / Bed, or whatever you call it, looks very rugged and strong! Are the blue parts, ends, etc., a different kind of metal? Does the sled move on free rolling Rollers but controlled with cables? What is the main way the movements are controlled? A. Probably 90% of the machine is made out of mdf. About the only metal parts are the pipes that the skateboard bearings run on and the threaded rod that controls the travel. The machine moves three different ways x, y & z ( x-left & right y-across the table & back z -up & down) and there is a stepper motor that your computer controls for each of these axis. The stepper motor is attached to a threaded rod (in my case a 1/2"x 18) and this controls how far & in what direction the machine travels for each cut. Sounds complicated but after watching one work a couple of times, everything falls into place. (5) Can you give us a Link to the Forum(s) that you used to get help as well as any other helpful Links? A. http://www.cnczone.com/forums/showthread.php?t=15139 You will have to register to see the pictures - which you must do to appreciate this machine. (6) What are the sources data types from which you can work? For your sign; jpg or graphic pic? Mech. drawing, CADCAM software? A. The software I use to do most of the drawing is Vcarve Pro - http://www.vectric.com/WebSite/Vectr.../vcp_index.htm and the software to control the CNC is Mach3 - http://www.machsupport.com/artsoft/index/index.htm. As far as I am concerned, this is the best and simpliest software I have seen. Some of the other software cost $1000's and takes a rocket scientist to use. (7) Does your software use the machine to determine wood thickness or do you explicitly tell it? A. I have to tell the software how thick the wood is. (8) If you wanted, could you change bits in the Knob Job to Roundover the outside edges? A. yes (9) How much do you leave uncut, at the bottom, to keep pieces in place? A. I tell the software how thick and how long to leave the tabs. (see question 2). I usually set mine up to leave the tabs 1/8" thick and 1/4"long. I can put as many tabs as I want and whatever size I think I need around a piece. Small pieces, I usually leave 2 tabs and on larger pieces I leave 4. This could change if I thought I needed more. Last edited by DougO; 08-12-2007 at 01:04 AM. Reason: add to |
| | #13 |
| Retired Moderator Supreme Forum King | Wow, now that is cool. Sweet machine! Corey
| | #14 |
| Forum Contributer Supreme Forum King | "You will have to register to see the pictures - which you must do to appreciate this machine." O dear Joe, does this mean that you are going to forgo the pleasure of visiting this forum? (refer to you're answer to my suggestion that registration be required to visit Router Forums.com)
__________________ Harry |
| | #15 | |
Thanks again! OOOOOO... The following links cannot be found... Error 404 http://video.google.com/videoplay?do...11940888627972 http://video.google.com/videoplay?do...45240137833037 http://video.google.com/videoplay?do...91859906584476 I'll have to do some studying... ![]() | |
| | #16 |
| Registered User Forum Fanatic | Oops, sorry about the links. I did not try them after I cut and pasted them. Try these links. I think they will work better. http://video.google.com/videoplay?do...11940888627972 http://video.google.com/videoplay?do...45240137833037 http://video.google.com/videoplay?do...91859906584476 |
| | #17 |
| Banned Supreme Forum King | Thank you! WOW! That looks like an Arm & a Leg to get into!! Those bits have to cost a lot more! ![]() |
| | #18 |
| Registered User Forum Fanatic | The bits are just regular router bits. The holders are what you are talking about costing. I am not sure what their cost is. I think they are @$25 each. |
| What email router tips do you want to see for 2006! | BobandRick | General Routing | 23 | 01-15-2007 11:48 PM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
| CNC Routing w/ AutoCAD 2006? | awh | Table-mounted Routing | 4 | 03-24-2006 10:56 PM |
