| | #1 |
| Forum Contributer Supreme Forum King | This is NOT CNC but almost as good and it's alot cheaper ![]() The one below is put in a bit deeper than most because it's going to get a white paint job... 3/4" MDF stuff http://www.jacquescoulombe.com/cmt04.htm http://www.mikestools.com/Rcs-Sts-Cm...ng-System.aspx http://www.routerforums.com/39491-post12.html http://www.routerforums.com/39515-post15.html ===========
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 12-31-2007 at 06:09 AM. |
| | #2 |
| Retired Moderator Supreme Forum King | Sweet Bj, you knew that would make me jealous That is cool and you didn't waste anytime putting that new bit to work. But man those things are expensive and the templates ain't cheap either. Nice work BJ. Good use for the ski equipment and winter is coming ![]() Corey
| | #3 |
| Forum Contributer Supreme Forum King | Bj., you know that I love to use the ski set-up, but I'm puzzled by the use of it with a 3D carver which relies on the cone, therefore the router moving up and down as the groove width in the template varies. How then did you achieve such results in the ski mode? Did you operate the router by it's handles with it unlocked, if so, I don't see any advantage in using the skis. Based on past experience, I'm sure that I have missed something, what?
__________________ Harry |
| | #4 |
| Forum Contributer Supreme Forum King | Hi Harry You'er Right no real advantage in using the skis for this job , but the skis help hold the weight off the router and off the template and because the templates need to be removed and fliped over many times it helps me keep the bit out of the template that's to say it's so easy to plunge the router down in the wrong place and wiping out a template the siks keeps me in the right spot..right over the template.. ![]() And you'er right again the router bit the with the cone bearing is the key for this type of carving.....plus the computer CNC made templates... ![]() I did add a snapshot of one more type to the 1st. post and sometime this week I will add a Eage and a Spanish Fan and maybe one or two more other types..just for kicks.. =======
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ |
| | #5 |
| Forum Contributer Supreme Forum King | Just more 3D Carvings done with the CMT templates and the ski jig setup.. ![]() It's so easy, it's like painting by the numbers in away...but the brush is a router and router bit, it's hard to screw up unless you do like I did, using the template the wrong way or to say over guessing the guy/machine that made the template. ==============
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 10-20-2007 at 10:32 AM. |
| | #6 |
| Retired Moderator Supreme Forum King | Very cool bj, love seeing your toys Did you make the template holder or is that made by the template manf? Thanks for the photos BJ!Corey
| | #7 |
| Forum Moderator Supreme Forum King | Bj, Nice job!
__________________ Cheers, Bob Pictures from the shop http://s107.photobucket.com/albums/m292/bnoles616/ |
| | #8 | |
| Forum Contributer Supreme Forum King | Hi Corey Thanks,,,,, the " template holder " comes with the one of the door templates,, It's 3/8" thick MDF,,, the templates are all 3/4" thick MDF...so it's easy to use the holding frame, sits on just about anything but I used the holding frame I made for Template Tom/HarrySin way of using templates.. drilled 8 holes in the holding frame and screwed it down to the board into the tee-nuts...makes it quick and easy to mount the blank board for the router job...The Eagle, I though was going to be the hard one, it's the easy to do ,,it takes 4 templates and can be put on left or right (head facing) takes about 10 mins.or so to get the job done... the hard one was/is the fan... still playing with that one...========== Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ | |
| | #9 | |
| Forum Contributer Supreme Forum King | Thanks Bob ============ Quote:
| | #10 |
| Forum Contributer Supreme Forum King | OK Bj. how many templates did you buy and what was the cost? As I mentioned before, I don't know why you're using the skis for this type of job when it's a case of PLUNGE routing for the 3D effect, the skis becoming redundant. In spite of this you really have done a first class job, as we have all come to expect from you. I've only got one template which I've used on drawer fronts, jewellery boxes and a blanket chest. I'm not surprised that you gave up on the idea of making you're own templates, I reckon some kind of CAD programme would be required.
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 08:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 06:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 02:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 12:02 PM |
| New Router my way | reible | General Routing | 14 | 06-10-2006 10:19 PM |
