| | #1 |
| Registered User New Member | I work in a machine shop and we are trying to learn how to take a photo and place it in wood and or metal. If anyone has tried to do the same I would like to hear from you. Thanks, Tony |
| | #2 | |
| Banned Supreme Forum King | Quote:
Sounds like you're interested in a Laser engraving / carving system... Not sure of the extact name, except I know it uses a laser... Used in making pictures, etc. on head stones & wood. I'm sure someone will come with more information for you. Enjoy... | |
| | #3 | |
| Forum Contributer Supreme Forum King | Hi Tony I'm not to sure if this is what you are looking for BUT the software that you can download from the web site and try out will let you put in a picture/photo it's not CNC software it's like printer software so to speak. See the 1st. link below for some show and tell items. I would think that you could use Alum. in place of the wood but not 100% sure on that one but I don't see why not. See the links below http://www.routerforums.com/wood-scr...ll-shelft.html http://www.carvewright.com/ Bj ![]() Quote:
__________________ Bj | |
| | #4 |
| Banned Supreme Forum King | Tony, I did a Google on "laser engraving"... this is ONE of the hits that will give you an idea of what can do what you want... ... for a price, of course. ![]() http://www.signwarehouse.com/engravers/pinnacle_m.htm Let us know what you end up getting... OK? Take care... |
| | #5 |
| Registered User New Member | Actually I have mounted a 24000rpm router to a CNC machining center. I am creating gcode in Bob Art-X. I am getting a smooth surface in the background but when I get to a face it leaves a rough surface. Not from the router but from the program creating code. Any suggestions as to how to create code with a smooth surface. Thanks |
| | #6 |
| Forum Contributer Supreme Forum King | You may want to check out the links below they may help, but I don't think it's the code it sounds like the picture your are using is not the right format or it not clean. ![]() But the guys on the forum below may have the info you need. ![]() http://www.carvewright.com/forum/ http://www.vectorart3d.com/ http://www.vectorart3d.com/index.cfm/QuickTour.htm http://www.vectorart3d.com/index.cfm/Software.htm Art work Below http://www.woodworkstuff.net/CarveAB1.html http://www.mikesphotos.woodwork2006.photoshare.co.nz/ http://www.mikesphotos.woodwork2006....yPresenter.asp Some great pens on this site plus some boxes BJ ![]()
__________________ Bj Last edited by bobj3; 03-24-2007 at 02:37 PM. |
| | #7 | |
Perhaps there is not much Contrast in it, leaving normal shaded sections in face, cheeks, around noses, foreheads, etc. If you were to increase the Contrast, you would basically be removing the fine shading (causing the machine problems to duplicate) and resulting in more contrast which is really nothing more than more black & white transformations and less shades of gray. Can you try increasing the contrast and trying it again? Sounds like you're breaking new ground... very interesting! Thank you for the feedback. | |
| | #8 |
| Senior Moderator Supreme Forum King | Tony, the CNC carving machines use a pointed carbide bit to achieve fine detail. Whiteside and other manufacturers sell these bits. This might help on your finish.
__________________ Mike |
| | #9 |
| Registered User New Member | sorry for bad english hehey greetings my friends lamentably I could not put the Link but search in google "from bmp to gcode" the company is called "majosoft" the program is free transforms an image "bmp" into "gcode" greetings from Argentina elvitual |
| | #10 |
| Registered User New Member | I have a CNC router. I bought Photo V Carve. I have tried a couple of times using different cutters so far I am not happy with the results - but there is promise to it. VECTRIC V Carve Pro and a couple of options like Photo V Carve is a nice CAM package. Experience is going to get me further. I may play around a bit more with the photo later today. If I gain success, I will try to post a pic. |
| wood residential and business sign routing with | mark disaverio | Introductions | 4 | 04-06-2008 10:31 PM |
| Framing a small piece of wood | lea6141 | Table-mounted Routing | 9 | 01-26-2008 09:29 PM |
| Routing Wood Clock Gears. | Wes Anderson | Introductions | 5 | 10-26-2007 11:22 PM |
| What kind of wood for routing signs | BC Wood Worx | Tools and Woodworking | 4 | 08-01-2007 08:28 AM |
| Questions about wood Pallets and moisture | GoonMan | Tools and Woodworking | 2 | 07-05-2005 07:11 PM |
