Go Back   Router Forums > Routers > CNC Routing
CNC Routing A place to discuss CarveWright, CompuCarve and other CNC routing devices.
Thread Tools Display Modes
Old 10-10-2007, 05:01 PM   #1
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Default 3D Router Carving
This is NOT CNC but almost as good and it's alot cheaper
The one below is put in a bit deeper than most because it's going to get a white paint job... 3/4" MDF stuff
http://www.jacquescoulombe.com/cmt04.htm
http://www.mikestools.com/Rcs-Sts-Cm...ng-System.aspx
http://www.routerforums.com/39491-post12.html
http://www.routerforums.com/39515-post15.html
3d-router-carving-7605.jpg  3d-router-carving-7606.jpg  3d-router-carving-7607.jpg  3d-router-carving-7608.jpg  3d-router-carving-7609.jpg
3d-router-carving-7610.jpg  3d-router-carving-7611.jpg  3d-router-carving-7612.jpg  3d-router-carving-7613.jpg  3d-router-carving-7614.jpg
3d-router-carving-7616.jpg  3d-router-carving-7617.jpg  3d-router-carving-7618.jpg  3d-router-carving-7619.jpg  3d-router-carving-7620.jpg
3d-router-carving-7621.jpg  3d-router-carving-7622.jpg  3d-router-carving-7623.jpg  3d-router-carving-7624.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-10-2007, 10:43 PM   #2
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Sweet Bj, you knew that would make me jealous That is cool and you didn't waste anytime putting that new bit to work. But man those things are expensive and the templates ain't cheap either. Nice work BJ. Good use for the ski equipment and winter is coming
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 10-11-2007, 08:52 AM   #3
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Bj., you know that I love to use the ski set-up, but I'm puzzled by the use of it with a 3D carver which relies on the cone, therefore the router moving up and down as the groove width in the template varies. How then did you achieve such results in the ski mode? Did you operate the router by it's handles with it unlocked, if so, I don't see any advantage in using the skis. Based on past experience, I'm sure that I have missed something, what?
Harry
harrysin is offline   Top - Reply with Quote
Old 10-11-2007, 07:03 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
You'er Right no real advantage in using the skis for this job , but the skis help hold the weight off the router and off the template and because the templates need to be removed and fliped over many times it helps me keep the bit out of the template that's to say it's so easy to plunge the router down in the wrong place and wiping out a template the siks keeps me in the right spot..right over the template..
And you'er right again the router bit the with the cone bearing is the key for this type of carving.....plus the computer CNC made templates...
I did add a snapshot of one more type to the 1st. post and sometime this week I will add a Eage and a Spanish Fan and maybe one or two more other types..just for kicks..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-19-2007, 04:39 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Just more 3D Carvings done with the CMT templates and the ski jig setup..
It's so easy, it's like painting by the numbers in away...but the brush is a router and router bit, it's hard to screw up unless you do like I did, using the template the wrong way or to say over guessing the guy/machine that made the template.
3d-router-carving-7660.jpg  3d-router-carving-7661.jpg  3d-router-carving-7663.jpg  3d-router-carving-7666.jpg  3d-router-carving-7668.jpg
3d-router-carving-7690.jpg  3d-router-carving-7700.jpg  3d-router-carving-7710.jpg  3d-router-carving-7720.jpg  3d-router-carving-7740.jpg
3d-router-carving-7750.jpg  3d-router-carving-7760.jpg  3d-router-carving-7770.jpg  3d-router-carving-7780.jpg  3d-router-carving-7730b.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-19-2007, 05:19 PM   #6
challagan
Supreme Forum King
challagan's Avatar
Very cool bj, love seeing your toys Did you make the template holder or is that made by the template manf? Thanks for the photos BJ!
Old 10-19-2007, 05:27 PM   #7
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Bj,
Nice job!
Cheers,
Bob
Bob is online now   Top - Reply with Quote
Old 10-19-2007, 06:15 PM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
Thanks,,,,, the " template holder " comes with the one of the door templates,,
It's 3/8" thick MDF,,, the templates are all 3/4" thick MDF...so it's easy to use the holding frame, sits on just about anything but I used the holding frame I made for Template Tom/HarrySin way of using templates.. drilled 8 holes in the holding frame and screwed it down to the board into the tee-nuts...makes it quick and easy to mount the blank board for the router job...
The Eagle, I though was going to be the hard one, it's the easy to do ,,it takes 4 templates and can be put on left or right (head facing) takes about 10 mins.or so to get the job done... the hard one was/is the fan... still playing with that one...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-19-2007, 06:16 PM   #9
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks Bob
Originally Posted by Bob N
Bj,
Nice job!
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-20-2007, 07:05 AM   #10
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
OK Bj. how many templates did you buy and what was the cost? As I mentioned before, I don't know why you're using the skis for this type of job when it's a case of PLUNGE routing for the 3D effect, the skis becoming redundant. In spite of this you really have done a first class job, as we have all come to expect from you. I've only got one template which I've used on drawer fronts, jewellery boxes and a blanket chest. I'm not surprised that you gave up on the idea of making you're own templates, I reckon some kind of CAD programme would be required.
Harry
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
