Help
Go Back   Router Forums > Routers > CNC Routing
Hold it Down
This is a discussion on Hold it Down within the CNC Routing forums, part of the Routers category; I'm looking for someone who has experience in holding down plastics to the table. The ...
Old 10-19-2007, 08:32 AM   #1 (permalink)
jetvich is on a distinguished road
Default Hold it Down
Report Post Report This Post!
I'm looking for someone who has experience in holding down plastics to the table. The vacuum works for large sheets, but when I'm making parts that are 12" and less the bits tear them out of place. I'm currently using double sided carpet seeming tape and the stuff is a dread for cleaning. Any suggestions?
jetvich is offline
Old 11-27-2008, 04:43 PM   #2 (permalink)
First Name: Errol
Errol is on a distinguished road
Hi Jetvitch,
Have you had a look at V-Clamps? vac-clamp.com. This might help you on your quest.
Errol is offline
Old 01-20-2009, 09:35 PM   #3 (permalink)
First Name: Peter
pwdavo is on a distinguished road
Having used my homebuilt CNC for some 6 years, I have tried almost everything. Now I use .5 throwaway MDF on bed and screw stock by corners, yes stock needs to be a little bigger but it works first time every time.
pwdavo is offline
Old 03-12-2009, 02:49 PM   #4 (permalink)
Vendor Account
First Name: Alex
blurrycustoms is on a distinguished road
I have had success with drilling a hole pattern in a 1/2"-1" thick MDF or HDPE table, say 5/16 holes on a 4"x4" grid, and then using a 1/4"-20 t-nut (similar to below) pressed into the bottom.
They run about $7-$8/100 pieces
Obviously you can use any grid spacing, but these t-nuts come a good variety of shapes and sizes from McMaster-Carr. This may extend the life of an otherwise disposable tabletop.
Just a thought!
blurrycustoms is offline
Old 03-25-2009, 08:20 AM   #5 (permalink)
Arcticfox46 is on a distinguished road
3M - double sided sticky tape --- its wicked strong and simple.
I use it all the time on my CNC machine
Heck - I use in on non CNC too
Arcticfox46 is offline
Old 10-20-2009, 11:19 AM   #6 (permalink)
First Name: Thomas
CNCWOODWORKER is on a distinguished road
Can you tell me exactly which 3M tape you use? They got about a million it seems. Also, how much does it cost per roll? I'm looking for a replacement for my current brand.
I've tried probably a dozen types through the years and have found Do It Best Brand carpet tape in the retro 70's looking box to be the best, but they rarely have it at my local stores anymore and I can't find it on their website either. It's also expensive.
This stuff is extremely sticky, and cleanup usually isn't an issue.
I've used it to hold down hard maple guitar necks and bodies and done some pretty heavy routing with no problems - except getting the part off the table when it's done.
CNCWOODWORKER is offline
Old 11-03-2009, 02:40 PM   #7 (permalink)
First Name: Ray
Axeman is on a distinguished road
A little denatured alcohol releases the 3m tapes instantly.
Axeman is offline
Old 11-03-2009, 04:49 PM   #8 (permalink)
BigJimAK's Avatar
BigJimAK is a name known to allBigJimAK is a name known to all
+1 on the double-stick tape
Alaska's North Slope: One of the few places in the U.S. where when two people casually talk about the temperature getting "down to 40", both know that means -40F! Brrrrr...
BigJimAK is offline
Screws to hold my T-tracks? deck99 Table-mounted Routing 3 04-20-2008 07:08 AM
Hold down clamps vapochilled Jigs and Fixtures 1 02-06-2008 07:56 PM
Hold the mice cbsjoez1935 Table-mounted Routing 14 05-03-2007 12:24 AM
Round table insert deck99 Table-mounted Routing 5 03-08-2007 01:58 PM
An alternative way to hold stock harrysin Guide Bushings and Templates 5 02-18-2007 02:47 PM
