| CNC Routing Discuss Cnc advice needed in the Routers forums; Hello all. I am doing a little research on wood cnc routers. I am in the stone business and I ... |
| New Reply | Quick Reply |
| | Thread Tools | Search this Thread | Display Modes |
| | #1 | ||
| Registered User |
Hello all. I am doing a little research on wood cnc routers. I am in the stone business and I am looking for something that I can make templates with out of wood. These templates will mainly be sink cutouts or intricate designs. For example I have .dxf files available to me for a particular sink. I then need to make a template for them out of wood or prefferably plastic so a bearing can ride along it to mill the stone perfectly. I usually make these by hand but I would like to get more precise. The average size of my template is 24"x48" The actual cutout is about (give or take a few inches) 30"x20''. This is all I would use this for so I am not looking to drop a serious amount of money. It will just sit in a corner of a fab shop most of the time. Any advice on what I should be looking for is greatly appreciated. Thanks in advance! mderzio | ||
| | #2 | ||
| Official Greeter Supreme Forum King |
I can't help with the templates, but welcome to the forums anyway mderzio . One of our members will surely answer your question.
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. | ||
| | #3 | |||
| Registered User Forum Geek |
May I suggest http://www.cnczone.com/forums/forumdisplay.php?f=385 Good hunting! ![]() Have a great wood working day! John
__________________ Cleaning my glasses will not make me look any better, but will make what I'm looking at better! | |||
| | #4 | ||
| Registered User Forum Fanatic |
If you have the time to build it yourself, I would suggest going to "CNCzone dot com" and looking up Joes2006 model. It would do the job you are talking about and total should be less than $2000 (not counting labor).
__________________ Doug | ||
| | #5 | |||
Check-out Joes Hybrid 4x4 as well, it is the next generation of Joes machine. It also can be found at... cnczone.com Good luck on your hunt, I am building the 2006 model of Joes. There are several support forums to assist in the building of either model. Have a great woodworking day. John
| | #6 | ||
| Marine Engineer Forum King |
mderzio, Try searching for someone in your area who can produce the patterns for you. How many patterns would you have to make for yourself to break even on the investment cost? How much shop space would you lose to a CNC machine you're not using? Unless you're going to use it to start engraving stone, it might be more cost effective to hire out your CNC work.
__________________ Doug 1 John 1:9 | ||
| Childs stove/fridge plan needed | BrianS | Project Plans and How To | 14 | 02-19-2007 11:06 PM |
| Need Advice On Router Purchase For Freehand Use | elmiko | General Routing | 9 | 06-20-2006 07:46 PM |
| Need Advice | cdmillion | Introductions | 2 | 03-31-2006 11:06 PM |
| Bandsaw advice needed | Bob N | Tools and Woodworking | 7 | 06-07-2005 03:15 PM |
| Advice Needed | denisd | Portable Routing | 3 | 09-28-2004 01:55 PM |
All times are GMT -5. The time now is 05:43 PM. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 |
