| CNC Routing A place to discuss CarveWright, CompuCarve and other CNC routing devices. |
| | #1 |
| Registered User New Member | OK, simply put, buddy of mine sent me a ton of 3/4" shank bits (usable in wood) of quality higher (many brand new) than anything I can get. Have LOTS of them - want to use. Can I 'try' and find a used or broken CNC - for the motor and fittings, and convert to a table mounted (underneath), or am I out of my mind? I know almost nothing of the CNC machines - and simply want the ability to utilize these bits. I've had the suggestion of getting a shaper table and having a custom fitted (fabricated) conversion for a CNC 3/4" collet - but that includes buying a shaper and then having the piece customized - then spinning the bits below their normal speed... Lots of hoops to jump through. If I'm out of my mind... Just let me know. thanx as always. |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi brettmansdorf That's something like getting a outboard motor for a boat and then making a boat to use the motor... It can be done but it's not going to be cheap..or easy ![]() Think of what you are wanting to do, just route some wood..and then once the bits wear out, then what ?, then you will have a new boat anchor.. Are you sure they are router bits or mill end tools ? ================ Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-20-2008 at 10:14 PM. | |
| | #3 |
| Registered User New Member | Agreed - just researching - thinking outloud... Getting 54 of the bits. Cannot sell a majority of them (with out going into it... they go to me or get destroyed). Shame as many are brand new. I've been in the market for a shaper or another router anyways... I've received these bits and figured I'd look into it. PS>>> Typically in smaller boats - the hull is low value, the motor is high value... |
| | #4 |
| Senior Moderator Supreme Forum King | Your best course of action if you want to use these bits is to buy a small mill that has a #2MT spindle. You can get collets for this that will accept 3/4" bits. Mills run at much lower speeds than a router. You will also be laying out so much cash for the mill that you are most likely better off trashing the bits and buying the proper router bits you can use.
| | #5 |
| Registered User New Member | Really appreciate the help... One of those 'lost causes' to add to the collection. Thanx again. |
