Go Back   Router Forums > Routers > CNC Routing
CNC Routing A place to discuss CarveWright, CompuCarve and other CNC routing devices.
Thread Tools Display Modes
Old 07-13-2008, 06:14 PM   #21
Check twice!
Forum King
Check twice!'s Avatar
Check twice! is on a distinguished road
Here is the jig I built to do our pipe. It is simple but seems to be working so far. I do need some washers 1 1/4" hole, the wooden ones I made are wearing away already. I inserted a piece of dowel into the pipe and drilled a hole through and put a nut and bolt. I then cut the head off a lag bolt and screwed it into the center of the dowel. The drill then tightens down on the lag bolt. Clamp it down and away we go.
I did use a file for a bit but I need a finer file or better sand paper, made for metal. We do have alot of work to do. Moving forward anyways.
Bob, I did try the sand belt reversed and it would work fine if I could have got the thing to track proper. The build is too rough for the fine tuning needed for tracking.
Have agreat day
John
new-build-cnc-router-img_1309.jpg  new-build-cnc-router-img_1308.jpg  new-build-cnc-router-img_1312.jpg  new-build-cnc-router-img_1313.jpg
John
Cleaning my glasses will not make me look any better, but will make what I'm looking at better!
Check twice! is offline   Top - Reply with Quote
Old 07-13-2008, 07:14 PM   #22
kp91
Forum King
kp91's Avatar
First Name: Doug
make sure that table saw motor is protected from those metal filings dropping down on it!
Good looking jig, hope it gives great results with little wasted effort!
1 John 1:9
Old 07-13-2008, 07:26 PM   #23
Check twice!
Forum King
You may think this is foolish of me, I did not think of that. It is a little protected, so that must mean it is a little unprotected.
I will Cover it with a plastic garbage bag.
I really thank you, it shows posting photos does pay.
Once again thanks for picking up on that.
John
John
Old 07-13-2008, 10:45 PM   #24
kp91
Forum King
kp91's Avatar
First Name: Doug
John,
The obvious is always what bites us in the rear! (A lesson I still learn regularly!)
Can't wait to see this project finished,
1 John 1:9
Old 07-19-2008, 08:13 PM   #25
Check twice!
Forum King
We have finally finished all the pipes, we still need a little bit of 3/4" rod but that we will clean by hand.
Our Acme and nuts are on back order and should be in the beginning of next week. Why do they let you go all the way there to pick up your material to find it has been delayed, wasted trip, time and patience. Grrrr
A couple of photos showing the jig for the 36" pipe, and the finished pipe. Now to cut it to length. The next move is the slide bearings.
Doug, the garbage bag is over the motor.
Have a great weekend
John/Scott
new-build-cnc-router-img_1330.jpg  new-build-cnc-router-img_1332.jpg  new-build-cnc-router-img_1333.jpg
John
Old 07-19-2008, 10:18 PM   #26
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
John;
Have you decided what electronics you will be using? What type of interface to the computer?
AxlMyk is online now   Top - Reply with Quote
Old 07-20-2008, 07:28 AM   #27
Check twice!
Forum King
Originally Posted by AxlMyk View Post
John;
We are buying our driver boards and motors from CNChobby, (Scott will be ordering them this week) this is a kit package about $300.00 for the kit. We are using 305 oz bi polar motors (last time Scott and I talked about this) and a 3 axis driver board.
Suggestions ???
We will be using Mach3 for the drivers and Vcarve for the cam/cad end. This we will get near the end of the build, as the cost is quite expensive.
Suggestions ???
Thanks Mike and you and yours have a great day.
John
John
Old 07-20-2008, 05:53 PM   #28
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
John when you take on a project wow thanks for the pics to show how many steps you had to take to do a cnc machine. Keep them coming. The hutch looks great glad to see one of us keeping busy. Can't wait to see the end results.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline   Top - Reply with Quote
Old 07-20-2008, 10:47 PM   #29
Senior Moderator
Supreme Forum King
Mike has disabled reputation
John, I used to buy my drive components from IDC in Warren, MI. They are just around the corner from me and I will inquire if they ship to Canada. (Better late than never)
I have a great deal of experience working on 6 axis back gauges on Cincinnati machines. If you run into any set up problems I may be able to assist you. From the little I have learned about home built CNC machines I think you made the best choice on using the Mach III software. Looking good so far.
Old 07-21-2008, 04:17 AM   #30
Check twice!
Forum King
Glenmore
I always like to reach for the stars, I really enjoy the challange of the build, and most of all the learning. Thanks for the kind words.
I do thank you and I am new to this buisness of CNC but learning quickly, from people like yourself. I have no doubts I will be looking for assistance at some point, and the diversified talents of the members is amasing. I thank you for the offer and I am sure I will be knocking.
Off to work, have a great day and chat soon.
John
John
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
I think my old router nearly killed me! peacefrog General Routing 5 09-23-2007 07:11 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
