Go Back   Router Forums > Other > Lobby > Forum Contests > Contests Archive
Contests Archive Previous forum contests and contest voting threads are archived here.
Thread Tools Display Modes
Old 09-28-2006, 08:32 PM   #61
BernieW
Forum King
BernieW's Avatar
BernieW is on a distinguished road
Default Walnut Plate Set
Here is a set of walnut plates I made out of kiln dried 6/4 stock 11 1/2" wide. All are around 11 1/8" across. They are finish with Mike Mahoney's walnut oil and after they have dried I put his combo of walnut oil/beeswax/carnubawax on them. After a couple of hours of drying I buff out on the lathe. They are going to be put in use on our table.
routerforums-com-oak-park-com-september-2006-contest-walnut-plate-set-2.jpg  routerforums-com-oak-park-com-september-2006-contest-walnut-platter-2.jpg  routerforums-com-oak-park-com-september-2006-contest-walnut-platter-11.jpg
BernieW is offline   Top -
Old 09-28-2006, 09:13 PM   #62
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
This is a walnut and oak box. The top is oak with a walnut handle. Oak miter keys on a walnut carcus. Finish is a home brew of oil varnish, tung oil and mineral spirits. Thanks for looking!
challagan is offline   Top -
Old 09-28-2006, 10:08 PM   #63
boardfoot
New Member
boardfoot is on a distinguished road
Attached is a photo of a baby cradle. It is made of oak with many coats of poleyurthane sanded between each coat. About 50 % is done with a router. I made everything except the spindles. It's made to swing or lock in a fixed position. Also, it will come apart for storage. I hope I at least get honorable mention.
Boardfoot
routerforums-com-oak-park-com-september-2006-contest-dcp_1367.jpg  routerforums-com-oak-park-com-september-2006-contest-dcp_1368.jpg
boardfoot is offline   Top -
Old 09-28-2006, 11:44 PM   #64
lebourdais
New Member
lebourdais is on a distinguished road
I never enter contests ... well ... only when the stakes are high. Anything from the guys at Router Workshop I consider way up there! So here goes ... enter my project in the contest. Thanks.
A close friend was looking for a small table for an older TV and I saw an opportunity to use my tools for a good reason other than just for chips and dust.
I started by disigning the legs, making two basic face frames and joining them together. The top was a mitered grooved frame with a plywood insert. Not being able to find a source for a black textured laminate, I decided to create my own. I had an old can of black enamel that was a quite thick. I poured a large glob on the plywood insert and used a paint roller to spread it out. What a mess! Next day I re-coated it using the same old roller. The effect was almost what I was looking for. Two or three coats of minwax satin poly and I liked it.
I used a Delta ShopMaster Router/Shaper with a pattern bit for the legs and a lot of round-over passes on the entire project. Bead-Loc loose tenons were used for all the joints on the frame. Number 20 Biscuits for the mitered table top frame and cleats.
That's all folks ... what did I win? Ray
routerforums-com-oak-park-com-september-2006-contest-1.-leg-template.jpg  routerforums-com-oak-park-com-september-2006-contest-4.-tv-table.jpg  routerforums-com-oak-park-com-september-2006-contest-2.-table-parts.jpg  routerforums-com-oak-park-com-september-2006-contest-3.-assembly.jpg
lebourdais is offline   Top -
Old 09-28-2006, 11:49 PM   #65
Scorpionjack
New Member
Scorpionjack is on a distinguished road
Post Contest Entry Spalted Maple Bookcase
Spalted maple,Wenge inlays, 1/2" Tiger Maple facing, Lazy Susan mounted on a Lexican routed glide tracks
routerforums-com-oak-park-com-september-2006-contest-logan-bookcase-front.jpg  routerforums-com-oak-park-com-september-2006-contest-logan-bookcase-side.jpg
Scorpionjack is offline   Top -
Old 09-28-2006, 11:55 PM   #66
Scorpionjack
New Member
Post Contest Entry Maple and Wenge Head and Foot Boards
Sorry not much on words! Attached is pictures of another project I did for my youngest Grandchild. Solid Maple trimmed in Wenge.
routerforums-com-oak-park-com-september-2006-contest-foot-back.jpg  routerforums-com-oak-park-com-september-2006-contest-foot-front.jpg  routerforums-com-oak-park-com-september-2006-contest-head-back.jpg  routerforums-com-oak-park-com-september-2006-contest-head-front.jpg
Old 09-29-2006, 12:53 AM   #67
DougW
Member
DougW's Avatar
DougW is on a distinguished road
Default Custom Oak Microwave stand
Looks like very stiff competition!
This microwave stand is solid oak with aspen as the secondary wood. It has a cookie sheet compartment (upper left) and a bread board to hold hot plates out of the microwave. Heavy duty drawers below and a cupboard above with raised oak panels. All on a mortise and tennoned frame with tongue and groove back boards.
Legs are cast iron lion-paw design in gold and silver.
The finish, done by my wife, is aniline dye, home-made shellac, and several coats of Varathane.
We are currently designing a pie safe to go with it.
...Doug
DougW is offline   Top -
Old 09-29-2006, 08:12 AM   #68
decarlowoodworks
decarlowoodworks is on a distinguished road
Default Oak Corner Cabinet
This oak corner cabinet stands at 7 feet and has all home sawn mouldings complete with a curio lamp.
decarlowoodworks is offline   Top -
Old 09-29-2006, 11:54 AM   #69
boardfoot
New Member
Default Contest entry
Attached are photos of an airplane rocker I built for my grandson. It is a disign and build or build and disign depending what stage it was in at any given time. My daughter-in-law is a pilot for United, so I thought it would be a good project. Everything is made from scratch. The propeller is hand carved.
Boardfoot
routerforums-com-oak-park-com-september-2006-contest-160a.jpg  routerforums-com-oak-park-com-september-2006-contest-39bc.jpg  routerforums-com-oak-park-com-september-2006-contest-ba6b.jpg
Old 09-29-2006, 02:20 PM   #70
john bee
New Member
john bee is on a distinguished road
this is a saxony type old english spinning wheel circa 1730 in common use in the north of england until arkright in vented mechanical spinning.this I made for my daughter in law to go in her old farm house,the real thing would cost a fourtune.
john bee is offline   Top -
