How to check for air gap..? - Page 2 - Router Forums
 9Likes
post #11 of 12 (permalink) Old 12-14-2016, 12:01 AM Thread Starter
Thank you all for your valid suggestions...
SusanneX16 is offline
post #12 of 12 (permalink) Old 12-28-2016, 11:30 PM
A common use of the term "air gap" in home plumbing refers to a fixture that provides back-flow prevention for an installed dishwasher. This "air gap" is seen above the countertop as a small cylindrical fixture mounted parallel with the faucet. Below the countertop, the drain pipe of the dishwasher feeds the "top" of the air gap, and the "bottom" of the air gap is plumbed into the sink drain below the basket, or into a garbage disposal unit. When installed and maintained properly, the air gap works as described above, and prevents drain water from the sink from backing up into the dishwasher, possibly contaminating dishes.[2] Water flowing from the fixture into the sink indicates a need for maintenance or repairA common use of the term "air gap" in home plumbing refers to a fixture that provides back-flow prevention for an installed dishwasher. This "air gap" is seen above the countertop as a small cylindrical fixture mounted parallel with the faucet. Below the countertop, the drain pipe of the dishwasher feeds the "top" of the air gap, and the "bottom" of the air gap is plumbed into the sink drain below the basket, or into a garbage disposal unit. When installed and maintained properly, the air gap works as described above, and prevents drain water from the sink from backing up into the dishwasher, possibly contaminating dishes.Water flowing from the fixture into the sink indicates a need for maintenance or repair.
jusiamchez112 is offline
Human Verification
Dryer not heating? Check the power wiring. AxlMyk DIY and Renovation 11 01-13-2010 08:44 PM
Fair Enteries BernieW Woodturning and Lathes 7 08-01-2007 06:44 PM
