closet built in 3/4 MDF or 1/2 plywood? - Page 2 - Router Forums
 15Likes
post #11 of 17 (permalink) Old 12-09-2016, 05:53 PM
First Name: Ed
Agree 100% on the plywood, I do not like MDF for any structural project.
herrwood is offline
post #12 of 17 (permalink) Old 12-09-2016, 08:11 PM
Ply. I had a lot of problems with HD ply because two layers were thin strips of bamboo. Hoorible crap material that splinters when you cut a dado. 3/4 ply is your best bet, but really check it out carefully first. Great project, by the way.
DesertRatTom is online now
post #13 of 17 (permalink) Old 12-09-2016, 11:01 PM Thread Starter
Everend's Avatar
First Name: Everend
If you aren't using drawer slides, i.e. just sliding them on wood frames, then I suggest using narrow strips of counter top laminate to slide them on. A strip on the runner in the carcass and another on the bottom of the drawer. You will be surprised at how well that works. If they get a little sticky you just rub some parafin on the drawer runners. I did that for some cupboards I built just after me and the missus got married and we didn't have much money to spare. Costs almost nothing but it is a little time consuming cutting the strips.
Good idea, I have some extra laminate that will work well for that. I had thought to use UHMW tape but I think the laminate is a better idea. less expensive since I can use scrap and since its thicker the structure of it will overcome slight inconsistencies in the plywood.
Roy Drake likes this.
Everend is offline
post #14 of 17 (permalink) Old 12-09-2016, 11:10 PM Thread Starter
Everend's Avatar
First Name: Everend
Originally Posted by Eugd View Post
I built this whole closet that spans the wall out of home depot $39 dollar plywood, real solid, I can't afford the Baltic birch stuff.
Eugene, that looks great! Did you edge band the plywood structure or is it just hidden by the drawer fronts and doors?
thanks
Everend
Everend is offline
post #15 of 17 (permalink) Old 12-10-2016, 01:21 PM
First Name: Eugene
Thanks, I did hardwood face frame about 3/4 thick, I did 1 inch and 3/4 x 3/4 hardwood face frame where 2 carcass so the euro hinges could mount, the rest of the face frame was just a faca board for the crown molding and toe kick instead of edge banding, I think hardwood is so much better than edge banding, makes the plywood more ridgid and stable, also I shellaced and pollyed the inside so it very smooth inside the cabinet, the whole project was under $900 with the hardware and wood.
Eugd is online now
post #16 of 17 (permalink) Old 12-10-2016, 01:24 PM
First Name: Eugene
$29 is a better than I got it, good luck with your build,
Eugd is online now
post #17 of 17 (permalink) Old 12-10-2016, 02:02 PM
RainMan 2.0's Avatar
You did well . I just spent $106 this morning for a 1/2" piece of Baltic birch . kicking myself as it was on sale for 35 bucks last week
If at first you don't succeed , then skydiving is not for you
RainMan 2.0 is online now
Human Verification
3/4 inch spiral up cut bit SRVDVM Router Bits - Types and Usage 32 09-29-2013 09:08 PM
Need some advice and plan for Closet Organizer fstellab Starting Off 2 12-28-2012 07:52 PM
Built in book shelf/ Shopnotes Clamp rack fasttruck860 Show N' Tell 14 09-25-2009 11:40 PM
Trimming mitered hardwood edging Drew Eckhardt General Routing 5 10-11-2008 08:59 PM
Fastest Bit for cutting 1/2 Plywood??? nicksorenson Router Bits - Types and Usage 2 06-02-2008 06:19 PM
