Turning Mirrors to glass - Router Forums
 4Likes
  • 1 Post By OPG3
  • 1 Post By Danman1957
  • 2 Post By sunnybob
post #1 of 9 (permalink) Old 01-29-2013, 06:29 PM Thread Starter
Marco's Avatar
Cutting to the chase........... I have a chance to get 3'x4' mirrors for all but free, is there a way to remove the reflective material (Metal/paint/?/?/) or what ever it is they use these days so that the clear glass is left?
Galatians 5:13
Marco is offline
post #2 of 9 (permalink) Old 01-29-2013, 10:03 PM
kp91's Avatar
First Name: Doug
Remove Silver Backing from a Mirror (To clear glass, not an Antique Mirror Instructable)
You can try this... no guarantees
1 John 1:9
Fredericksburg, VA
My daughter amazes me https://houndsathazelwild.wordpress....houndgold2016/
kp91 is online now
post #3 of 9 (permalink) Old 01-30-2013, 07:39 AM
OPG3's Avatar
First Name: Otis
Jim, Doug's post above provides good workable instructions. I have found that for my situations it was more trouble than it was worth. Glass is relatively cheap and [at least] around me, there are numerous companies that cut and sell glass.
Good luck my friend,
DaninVan likes this.
OPG3
Tweak everything!
OPG3 is offline
post #4 of 9 (permalink) Old 01-30-2013, 10:50 AM
Danman1957's Avatar
Hi Jim,
Have you considered asking a glass shop if they would exchange them. Mirrors are more expensive so maybe they would consider if the condition is good.
Cheers,
Dan
OPG3 likes this.
Danman1957 is offline
post #5 of 9 (permalink) Old 01-30-2013, 04:30 PM Thread Starter
Marco's Avatar
I did find a couple of usefull sites on removing the backing similar to the one linked.... I assume the mirriors in question are the cheaper version and have either chrome or alluminum instead of the silver... either way some paint stripper and a stripper for the reflective material and I'll have clear glass (I hope) ....54x42 mirrors or clear glass, 22 in all for $10 its worth it. I will happily frame a custom mirror for someone or use the glass
Around here it $3 per square foot for regular pane glass which is a few pennies more than plexi glass. The glass in those mirrors would run $47.25 a piece.
Galatians 5:13
Marco is offline
post #6 of 9 (permalink) Old 11-07-2016, 01:17 AM
Mirrors have a coat of silver, coat of lead paint and finally a coat of base paint. Try glass etching with paint stripper. You will have to repeat it to get it completely removed.
SusanneX16 is offline
post #7 of 9 (permalink) Old 11-07-2016, 04:40 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Marco, one thing to consider, how much are you going to spend on removal equipment? Sometimes a bargain turns out to be more expensive than new when the final bill is totted up.
My sister often spends more money repairing stuff than buying new, and she cannot understand why I just start fresh.
sunnybob is offline
post #8 of 9 (permalink) Old 11-07-2016, 04:29 PM
Apparently your time isn't worth anything, Marco...
Seriously, if it took you two days to work your way though 40+ panes (plus chemicals), that's got to be a $500 bill(?)
I've broken down patio door sealed units and cleaned them up for reuse, but that's 5mm tempered glass I was salvaging, not single or double weight window glass.
Out of curiosity, where did all these mirrors come from? Uh oh; don't ask don't tell...
DaninVan is online now
post #9 of 9 (permalink) Old 11-07-2016, 05:19 PM
JOAT's Avatar
First Name: Theo
If it were me, I might keep one or two; but the rest would be sold or traded.
NC via the Army in 1979; retired 1981, just east of Raleigh ever since.
Remember, when I tell how I do something, that does not mean I recommend you do it my way. Different backgrounds, experiences; what works for me, may not for you.
No point in believing in things that exist. If they exist, you don't have to believe, they just are.
JOAT is online now
Human Verification
Rail & Stile for flat panel & glass doors Brian.Crawford Router Bits - Types and Usage 7 01-29-2011 01:51 PM
Turning hickory crquack Woodturning and Lathes 9 11-20-2009 12:21 AM
Rail/Stile Red Oak and Stained Glass Lamp (Lots of Pics)… Nickbee Show N' Tell 8 01-08-2009 09:50 AM
Stained Glass Accent Lamp Build Along… Nickbee Show N' Tell 29 11-07-2008 05:46 PM
