Recycling leftover materials - Router Forums
 3Likes
  • 2 Post By papasombre
  • 1 Post By SusanneX16
post #1 of 9 (permalink) Old 08-21-2015, 05:36 PM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, guys.
Businesses are not good nowadays. A cousin of mine reduced the size of his offices due to the economic recession and, having no space for the leftover materials he asked to me to keep them in my garage. I wanted to buy the materials but he decided to give me all of them in exchange of some items I had at home.
Among the materials there were three planks of 15mm thick agglomerate along with several sections of the same material, several pieces of 3mm hardboard covered with a blue high pressure laminate, pine slats and a grill for barbecues.
Most of the pinewood was used to make the second high chair for Sabrina (posted here recently).
The agglomerate came timely for the construction of new kitchen wall cabinets for my daughter. This is a WIP.
Since the 3mm hardboard are not easy to find locally and when you do the prices are abusive, I decided to recover them to use as the back cover for the cabinets by removing the HPL. I have made this before with small pieces so I started with the smallest one. Taken all the precautionary measurements, since I used gasoline as solvent for the contact cement glue, I accomplished the job and additionally, I got some pieces of blue HPL that will be used, after a meticulous clean process, for areas non exposed to the view.
DaninVan and P.A. Gosselin like this.
We, woodworkers are everywhere!!!
papasombre is offline
post #2 of 9 (permalink) Old 08-22-2015, 08:04 AM
First Name: Gary
Alexis, DO NOT EVER USE GASOLINE INDOORS! The laminate comes off easily with a normal household clothing iron, and you can protect the laminate/iron with a paper bag.
gmercer_48083 is online now
post #3 of 9 (permalink) Old 08-22-2015, 12:19 PM
Alexis I've used the laminate for drawer runners in the past. They work very well. A strip under each drawer side and and a strip on each drawer support on the carcass. If they get a little sticky you just have to rub the ones on the drawer with paraffin (candle wax) and they slide good again.
post #4 of 9 (permalink) Old 08-22-2015, 03:08 PM
P.A. Gosselin's Avatar
First Name: Pierre
Alexis, I love the tiled floor of your outdoor work area. I imagine clean up must be a 'breeze'. Do you worry about chemical spills on the tiles?
No day has been worth living unless I learn something new, no matter the source.
P.A. Gosselin is offline
post #5 of 9 (permalink) Old 11-04-2015, 10:28 PM
Hi, that's a great idea to be economical and a budget savvy thing but be careful too with the gasoline that you use.
tidyswoop is offline
post #6 of 9 (permalink) Old 11-05-2015, 01:25 AM
Pierre; exterior and interior tile flooring is the standard in Central and South America.
It's cool to walk on and unaffected by rot, water, and insects.
It's easy for any one to hand mix and pour a slab, then tile over. Tile's cheap and so is labour.
Wood or lino are not a really great idea down there.
DaninVan is offline
post #7 of 9 (permalink) Old 11-07-2016, 01:01 AM
Nice way of recycling things...
DaninVan likes this.
SusanneX16 is offline
post #8 of 9 (permalink) Old 11-07-2016, 01:57 PM
Zero Waste
Susanne; you probably noticed that Alexis is posting from Venezuela. Almost everything down there is either in short supply or not available. Our guy Alexis is a saint in the Church of Recycling! Check out his past uploads and threads; you'll be amazed.
DaninVan is offline
post #9 of 9 (permalink) Old 11-07-2016, 10:28 PM
MT Stringer's Avatar
Dang, and all this time, I thought recycling pallets were hard work!
MT Stringer is online now
Human Verification
materials for jigging dovetails and box joints almost there Jigs and Fixtures 4 10-29-2012 10:23 AM
Great place to get materials and help the community dutchman 46 Project Plans and How To 1 03-11-2010 03:37 PM
Materials source George II Lobby 2 11-16-2009 12:15 AM
Leftover wood, fun projects Check twice! Show N' Tell 12 02-17-2009 05:54 PM
what to do with leftover solvents fasttruck860 The Finishing Touch 8 01-17-2009 05:12 PM
