Go Back   Router Forums > General Woodworking > Tools and Woodworking > Dynamic Calculators
Dynamic Calculators Check out our easy to use dynamic calculators! Customize boxes, bookshelves, and coffee tables! Simply enter the dimensions of your project, click on calculate and the cut list will be provided for your specific project.
Thread Tools Display Modes
Old 11-26-2005, 08:56 AM   #11
Tony
Jr. Member
Tony is on a distinguished road
Well I just tried it and I think it is a great tool I am sure going to use it a lot in the futer.
I hope that you keep this tool available to us and keep sending us more tips were we can use this tool
Tony
Tony is offline   Top - Reply with Quote
Old 11-26-2005, 09:17 AM   #12
Mackdaddy
Mackdaddy is on a distinguished road
The directions are easy to follow and the dynamic calculator is a GREAT help. Projects just got easier!
Mackdaddy is offline   Top - Reply with Quote
Old 11-26-2005, 09:45 AM   #13
JohnG
JohnG is on a distinguished road
Thumbs up PDF Format
Well done. I think that this calculation format is very well suited for woodworkers that own a thickness planer.
JohnG is offline   Top - Reply with Quote
Old 11-27-2005, 03:06 AM   #14
Mark
Forum Administrator
Supreme Forum King
Mark's Avatar
First Name: Mark
Mark is an unknown quantity at this point
Glad to see the feedback guys, thanks a lot.
Mark,
Administrator and Technician of RouterForums.com
RouterWorkshop.net - Get more out of your router!
Mark is offline   Top - Reply with Quote
Old 11-27-2005, 10:03 AM   #15
daleclem
daleclem is on a distinguished road
I liked the format. But for one box it seems unnecessary. When this gets expanded for larger projects with multiple pieces then I can see a greater advantage to using the calculator.
daleclem is offline   Top - Reply with Quote
Old 11-27-2005, 11:05 AM   #16
lwitherow
lwitherow is on a distinguished road
Great job, makes custom sizing a snap
lwitherow is offline   Top - Reply with Quote
Old 11-28-2005, 09:11 AM   #17
fredetl
fredetl is on a distinguished road
Default Dynamic Calculator
This looks like a very useful tool. Will you be releasing a version that allows it to be used for other type projects?
fredetl is offline   Top - Reply with Quote
Old 11-28-2005, 10:15 AM   #18
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
We were thinking that each project would have its own version of dynamic calculator. It would be used as a learning tool to help teach the math of each of the choosen projects.
Rick and Bob
The Router Guys
Old 11-28-2005, 10:18 AM   #19
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Yes there are many levels of projects that this technique can be used for. For the example we have the beginner level with additional lessons on why the math is as it is.
Rick and Bob
The Router Guys
Old 11-28-2005, 10:24 AM   #20
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Originally Posted by GOVarney
It could be good but it will require more effect and could lead to mistakes being made as in the example. If you listen to the first audio grab it says changes the values and the dynamic material will change. This doesn't work !!! Well not straight away, you have to go down and change the number of boxes from 0 to 1 or greater. But the first audio doesn't say this.
Now you could fix this by changing the default number of boxes to say 1. But then the 3rd audio grab would need to be re-recorded. As it talks about having 0.
As I said could be good, but could lead to mistakes.
By the time your ready to print the page all of the calulations will be correct.
This example was about the process and the fact that we could put audio within the PDF. With that said I will assume that this was a thumbs up as good features for a PDF document. Thanks for the comments.
Rick and Bob
The Router Guys
Raised Panel Door Calculator macattack Dynamic Calculators 4 10-24-2007 11:27 PM
Free calculator for fractions and other things mwm500 Links Database 1 11-21-2006 07:35 PM
Dynamic Calculators GoonMan Dynamic Calculators 4 03-29-2006 09:16 PM
