Go Back   Router Forums > General Woodworking > Tools and Woodworking > Dynamic Calculators
Rate This Thread - PDF Dynamic Calculator.
Thread Tools Display Modes
Old 11-28-2005, 09:26 AM   #21
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Originally Posted by GoonMan
Maybe I did something wrong but when I clicked on the link it opened IE which I do not use anymore.
If the answers are going to be that i use Internet Explorer then i will not use it.
I like the ideal of being able to make everything from one list.
works fine with my firefox. It is a PDF and shouldn't need IE to open.
Rick and Bob
The Router Guys
Old 11-28-2005, 09:29 AM   #22
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Originally Posted by Pop_pop1
The Box Calculator is great if you are using rabbit or half dovetail joints. If you want to use through box joints or full dovetail joints the calculations will be wrong. The type of jointery used should be taken into consideration in the calculations. Maybe a fourth question? Thanks........Chuck
Each project choosen will have a customized calculator.
Rick and Bob
The Router Guys
Old 11-28-2005, 03:25 PM   #23
EdKeating
EdKeating is on a distinguished road
Default PDF calculator.
I'm using Full Acrobat 6.0 so I'm not a candidate to download the 7.0 or later reader to take advantage of all new features. (I think I'll keep my capability to create/modify PDF files intact, as you use full Acrobat instead of reader when both have been installed.)
The link to the project plans did not launch to the right site, it went to http://www.routerworkshop.com/index.html instead of http://www.routerworkshop.com/S100.html#14 (I used copy link location and pasted it into a browser window.)
The Audio played ok and the calculator seemed to function ok.
Overall it looks like it may be a valuable addition.
EdKeating is offline   Top - Reply with Quote
Old 11-28-2005, 05:00 PM   #24
jomar
jomar is on a distinguished road
I could not get the calculator to work. What am i doing wrong. I tried reloading it and various other things, but no go!
jomar is offline   Top - Reply with Quote
Old 11-28-2005, 05:11 PM   #25
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
What version of acrobat reader are you using. This will determine if you can open and use. You must use at least 5.0 or better with 6.0 or 7.0.
Rick and Bob
The Router Guys
Old 11-28-2005, 05:14 PM   #26
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
6.0 should work fine and you were able to use all of the present features.
Rick and Bob
The Router Guys
Old 11-28-2005, 08:16 PM   #27
GoonMan
Forum Geek
GoonMan's Avatar
GoonMan has a little shameless behaviour in the past
Hello Rick and Bob,
I miss spoke it worked fine after I had my stuff set right. Sorry I did not get back sooner.
Regards
Randy
PC Support Forums, Free on line virus Scan, The Parasite Fight,
Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ Twin Oaks Mill
GoonMan is offline   Top - Reply with Quote
Old 11-29-2005, 09:56 AM   #28
DougW
Member
DougW's Avatar
DougW is on a distinguished road
Default Great concept
You've made some fine use of new Acrobat technology, though it looks like an upgrade to version 7 is in order.
As for functionality, haven't you forgotten an important criteria? Specifically the design of the joints in the box?
From what I can see this is fine for a finger joints, but I don't think the measures would be correct for a half-lapped joint, hidden dovetails or some other methods. Maybe the next step is to add a choice list of joint type that would allow for this?
...Doug
DougW is offline   Top - Reply with Quote
Old 11-29-2005, 01:04 PM   #29
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
...Doug
Each of the projects will have all drawings required to build plus include the dynamic calculator to customize that specific project. This project is using the rabbet joint and construction details from plan 103 magic boxes.
Thoughtful plan to add choice of joinery for specific projects.
Rick and Bob
The Router Guys
Old 11-29-2005, 10:54 PM   #30
cheray
cheray is on a distinguished road
should be helpful
cheray is offline   Top - Reply with Quote
Raised Panel Door Calculator macattack Dynamic Calculators 4 10-24-2007 10:27 PM
Free calculator for fractions and other things mwm500 Links Database 1 11-21-2006 06:35 PM
Dynamic Calculators GoonMan Dynamic Calculators 4 03-29-2006 08:16 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
