| Dynamic Calculators Check out our easy to use dynamic calculators! Customize boxes, bookshelves, and coffee tables! Simply enter the dimensions of your project, click on calculate and the cut list will be provided for your specific project. |
| | #1 |
| Forum Administrator Supreme Forum King Join Date: Aug 2004 Location: Winnipeg, Manitoba, Canada First Name: Mark Posts: 3,760 ![]() | Provide comments and feedback on the new Router Workshop PDF Dynamic Calculator. For more information regarding the PDF Dynamic Calculator, click the link below. http://routerforums.com/pdfc05/
__________________ Mark, Administrator and Technician of RouterForums.com RouterWorkshop.net - Get more out of your router! |
| | #2 |
| Registered User | Now were getting some where.[ |
| | #3 |
| Registered User New Member | I think that this will be a help. I like the changes that you are making . |
| | #4 |
| Registered User | Thanks: I think it will be a great help. |
| | #5 |
| Registered User | It could be good but it will require more effect and could lead to mistakes being made as in the example. If you listen to the first audio grab it says changes the values and the dynamic material will change. This doesn't work !!! Well not straight away, you have to go down and change the number of boxes from 0 to 1 or greater. But the first audio doesn't say this. Now you could fix this by changing the default number of boxes to say 1. But then the 3rd audio grab would need to be re-recorded. As it talks about having 0. As I said could be good, but could lead to mistakes. |
| | #6 | |
| Registered User | Quote:
| | #7 |
| Registered User Jr. Member | It looks good to me. I'm on it already. Thanks for all the work that you've put into this guys. |
| | #8 |
| Retired Moderator Forum Geek | Maybe I did something wrong but when I clicked on the link it opened IE which I do not use anymore. If the answers are going to be that i use Internet Explorer then i will not use it. I like the ideal of being able to make everything from one list.
__________________ Regards Randy PC Support Forums, Free on line virus Scan, The Parasite Fight, Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ |
| | #9 |
| Registered User New Member | Great help now and in the future, now I do not have to be online to use the Calculator. Thank you. |
| | #10 |
| Registered User Forum Fanatic | The Box Calculator is great if you are using rabbit or half dovetail joints. If you want to use through box joints or full dovetail joints the calculations will be wrong. The type of jointery used should be taken into consideration in the calculations. Maybe a fourth question? Thanks........Chuck
__________________ PopPop If it's worth building, It's worth building well. poppop@routerforums.com |
| Raised Panel Door Calculator | macattack | Dynamic Calculators | 4 | 10-24-2007 11:27 PM |
| Free calculator for fractions and other things | mwm500 | Links Database | 1 | 11-21-2006 07:35 PM |
| Dynamic Calculators | GoonMan | Dynamic Calculators | 4 | 03-29-2006 09:16 PM |
