Go Back   Router Forums > General Woodworking > Tools and Woodworking > Dynamic Calculators
Dynamic Calculators Check out our easy to use dynamic calculators! Customize boxes, bookshelves, and coffee tables! Simply enter the dimensions of your project, click on calculate and the cut list will be provided for your specific project.
Thread Tools Display Modes
Old 11-25-2005, 12:00 AM   #1
Mark
Forum Administrator
Supreme Forum King
Mark's Avatar
First Name: Mark
Mark is an unknown quantity at this point
Default PDF Dynamic Calculator
Provide comments and feedback on the new Router Workshop PDF Dynamic Calculator.
For more information regarding the PDF Dynamic Calculator, click the link below.
http://routerforums.com/pdfc05/
Mark,
Administrator and Technician of RouterForums.com
RouterWorkshop.net - Get more out of your router!
Mark is offline   Top - Reply with Quote
Old 11-25-2005, 03:43 PM   #2
mytime118
mytime118 is on a distinguished road
Thumbs up PDF Dynamic Calculater
Now were getting some where.[
mytime118 is offline   Top - Reply with Quote
Old 11-25-2005, 06:33 PM   #3
idahodale
New Member
idahodale is on a distinguished road
I think that this will be a help. I like the changes that you are making .
idahodale is offline   Top - Reply with Quote
Old 11-25-2005, 06:34 PM   #4
alm
alm is on a distinguished road
Default Dynamic Calculator
I think it will be a great help.
alm is offline   Top - Reply with Quote
Old 11-25-2005, 06:43 PM   #5
GOVarney
GOVarney is on a distinguished road
It could be good but it will require more effect and could lead to mistakes being made as in the example. If you listen to the first audio grab it says changes the values and the dynamic material will change. This doesn't work !!! Well not straight away, you have to go down and change the number of boxes from 0 to 1 or greater. But the first audio doesn't say this.
Now you could fix this by changing the default number of boxes to say 1. But then the 3rd audio grab would need to be re-recorded. As it talks about having 0.
As I said could be good, but could lead to mistakes.
GOVarney is offline   Top - Reply with Quote
Old 11-25-2005, 07:01 PM   #6
toolguy9
toolguy9 is on a distinguished road
Thumbs up pdf calculator
i think the pdf calculator is a good idea for making boxes in quantity so you can have all the info already figured out for you
toolguy9 is offline   Top - Reply with Quote
Old 11-25-2005, 10:05 PM   #7
Scotty
Jr. Member
Scotty is on a distinguished road
Thumbs up Calculator
It looks good to me. I'm on it already. Thanks for all the work that you've put into this guys.
Scotty is offline   Top - Reply with Quote
Old 11-25-2005, 10:48 PM   #8
GoonMan
Forum Geek
GoonMan's Avatar
First Name: Randy
GoonMan has a little shameless behaviour in the past
Maybe I did something wrong but when I clicked on the link it opened IE which I do not use anymore.
If the answers are going to be that i use Internet Explorer then i will not use it.
I like the ideal of being able to make everything from one list.
Regards
Randy
PC Support Forums, Free on line virus Scan, The Parasite Fight,
Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~
GoonMan is offline   Top - Reply with Quote
Old 11-26-2005, 12:30 AM   #9
bcruick
New Member
bcruick is on a distinguished road
Great help now and in the future, now I do not have to be online to use the Calculator. Thank you.
bcruick is offline   Top - Reply with Quote
Old 11-26-2005, 04:58 AM   #10
Pop_pop1
Forum Fanatic
Pop_pop1 is on a distinguished road
The Box Calculator is great if you are using rabbit or half dovetail joints. If you want to use through box joints or full dovetail joints the calculations will be wrong. The type of jointery used should be taken into consideration in the calculations. Maybe a fourth question? Thanks........Chuck
PopPop
If it's worth building, It's worth building well.
poppop@routerforums.com
Pop_pop1 is offline   Top - Reply with Quote
Raised Panel Door Calculator macattack Dynamic Calculators 4 10-24-2007 11:27 PM
Free calculator for fractions and other things mwm500 Links Database 1 11-21-2006 07:35 PM
Dynamic Calculators GoonMan Dynamic Calculators 4 03-29-2006 09:16 PM
