5 Reasons to Make Friends with Your Saw Shop - Page 3 - Router Forums
 35Likes
post #21 of 31 (permalink) Old 01-06-2017, 05:12 PM
Too many hits for saw blade or just blade for something quick. I had to go with google. Maybe one of us should put together a sticky thread that stays at the top of a category? That, glues, and maybe some others when there is time. I see too many people say they use T3 for everything and it isn't always the best choice or sometimes even a good choice.
Not sure what T3 is Chuck?
I am a little neglect sometimes for using the same blade "to make just one cut" over and over and over again, instead of changing to another blade.
Guess that is why they invented a combination blade for guys like me.
So to solve my problem I have a RA saw set up with a 60t, and one table saw set up with a 50 t combo , and the other table saw set up with the box cutter blade for rabbets and dadoes.
Herb Stoops is offline
post #22 of 31 (permalink) Old 01-06-2017, 05:24 PM
TightBond III glue...
here's the PR release...
Titebond III: Ultimate Wood Glue
but it does have it's limits and IS NOT the answer for everything...
do an experiment...
let you TB (any flavor) glue brush dry...
now go and run some hot water over the brush...
amazing!!!
the glue plasticizes and washes away...
and people wonder why their glue joints fail...
especially the projects that get a lot of sun...
post #23 of 31 (permalink) Old 01-06-2017, 07:34 PM
A combination blade is the one I don't have one of Herb. To me it's a case of compromising in exchange for versatility. It's not as good at ripping than a rip blade or crosscutting as a crosscut blade. I know that there is some economics involved for many people but my opinion is that if you can manage it, you will be better off in the long run if you buy one of each and get blades that are the best for what you want to do. The buying "one size fits all" is a case of short term gain but long term pain to my thinking.
Stick covered the other question better than I could have.
post #24 of 31 (permalink) Old 01-06-2017, 07:46 PM
Gr8trim4u's Avatar
First Name: Anthony
I have had good luck with my local ace hardware. 6 kapex blades and 3 ts55 blades for $90.00. They send them out to a local guy but they are best i have found in my area.
Not my first rodeo.
Gr8trim4u is offline
post #25 of 31 (permalink) Old 01-07-2017, 07:44 AM
Knothead47's Avatar
Closest sharpener is about 35 miles away. We had one south of town but the sign has been gone for several years now.
John T.
My wife gives sound advice. 99% sound and 1% advice.
Knothead47 is offline
post #26 of 31 (permalink) Old 01-08-2017, 05:39 PM
A lot of the small shops went out of bussiness when everyone went to carbide tip blades. Also the throw away blades hurt them too. Most lumber yards still are a drop off point for saw blade sharpeners.
post #27 of 31 (permalink) Old 03-28-2017, 07:13 PM
First Name: Bob
Just finished assembling my contractor SS. Everything went great until I had to assemble the switch to the saw. Found out that aligning the aluminum wing caused the hole to mount the electrical box were now out of align. So I enlarged the mount holes on the wing and remounted it 180. That worked but than the holes on the electrical bracket are very difficult to get the screws started, so I modified the bracket and was able to get it mounted, "what a pain". Yes a pain because the reason I bought the saw was I cut the tip off of my thumb with my General International TS. One more reason I bought this saw was because I had two TS accidents in two years. The first was my index finger and now my thumb.
bwilling is offline
post #28 of 31 (permalink) Old 03-29-2017, 04:59 PM
First Name: Bob
Sorry I misread this post to be Saw-Stop.
bwilling is offline
post #29 of 31 (permalink) Old 03-29-2017, 08:15 PM
Did you mean to print TS instead of SS Bob?
post #30 of 31 (permalink) Old 03-31-2017, 08:46 AM
First Name: Bob
SS is Saw-Stop. Just got off on the wrong tangent.
Cherryville Chuck likes this.
bwilling is offline
Human Verification
Newbie, needs advice bobadkinsfoto Introductions 13 04-22-2015 12:50 AM
Saying goodbye to my shop Duane Bledsoe Lobby 18 04-19-2015 03:59 PM
introduction. RailroadBill Introductions 8 01-25-2015 11:16 AM
Lets make a Jewlery Case neville9999 General Routing 1 11-21-2013 07:06 PM
One car shop make over fasttruck860 Show N' Tell 21 10-01-2009 04:47 AM
You may not post new threads
