GIVEAWAY: Triton Dual Mode Precision Plunge Router TRA001 - Router Forums
 137Likes
Closed Thread
post #1 of 225 (permalink) Old 02-15-2017, 10:19 AM Thread Starter
Administrator
Cricket's Avatar
First Name: Cricket
Default GIVEAWAY: Triton Dual Mode Precision Plunge Router TRA001
We are so excited to announce that we have partnered with Triton Tools to giveaway a Triton Dual Mode Precision Plunge Router TRA001!
To enter, simply reply to this thread with your response to the following question.
What tips would you offer to people just getting started with woodworking?
On March 1, 2017 we will do random drawings from the responses in this thread to select the winner.
Added Note: Responses to this thread should be limited to entering the giveaway by responding to the posted question.
Dual Mode Precision Plunge Router 2400W / 3-1/4hp
Powerful 2400W / 3-1/4hp electronically controlled motor. Single spanner Ďabove tableí cutter changing. Automatic shaft lock and power lock-off during cutter change mode. Fast plunge depth adjustment with winder handle and fine depth adjustment with micro winder. Quick switching to conventional plunge mode. Removable plunge spring for easy lifting and adjustment. Effective dust port.
  • 1/2" and 1/4" collet for a greater range of bit fitment
  • 3-1/4hp / 15A motor provides enough power for even the toughest timbers
  • Automatic spindle lock engages only when power switch cover is closed
  • Soft start and variable speed provides the perfect speed for all cutter types
  • Single button switches from plunge to fixed based router with rack and pinion adjustment
  • Micro winder enables continuous fine depth adjustment through the full plunge range
  • Rack and pinion height adjustment and table winder eliminates the need for expensive lifting mechanisms when used with router tables
  • Electronic speed control ensures a fine finish on all materials
  • Removable plunge spring for easy bit adjustment when table mounted
  • 3-stage turret with direct reading scales for precise pre-set cut depths
  • Fully enclosed guarding provides maximum protection from the cut zone and assists dust extraction
  • Multi-function fence provides optimum control for hand-held use and circle cutting
  • Quick-fit pins for fast fitment and removal from the fence and RTA300 Router Table
  • Side air vents reduce intake of dust into the motor casing when mounted upside-down in a router table
  • Excellent dust extraction for a cleaner, safer working environment
  • Easy access brushes allows the end user to change worn brushes
  • Single wrench bit change through the base is achieved with the automatic spindle lock
  • Safety Switch Shutter locks closed in bit-change mode to prevent router being switched on
Sponsored by: Triton Tools
"Show respect even to people who donít deserve it, not as a reflection of their character, but as a reflection of yours."
Cricket is offline
post #2 of 225 (permalink) Old 02-15-2017, 10:54 AM
Semipro's Avatar
First Name: John_*
My tip would be
Decide what you want to build, then plan the steps required to build these pieces, then get the tools to perform those tasks efficiently! Take your time and enjoy, ( work safely)
Semipro is online now
post #3 of 225 (permalink) Old 02-15-2017, 11:06 AM
difalkner's Avatar
First Name: David
Dry fit all glue joints before putting glue on them. If clamping is going to be complicated then test all the clamp positions before putting glue on the joints.
David
David
Nothing to do with woodworking at all, just our music at church (I'm the guy with the Koa Takamine) - Airline Baptist Church BC Songs
Romans 3:23
difalkner is offline
post #4 of 225 (permalink) Old 02-15-2017, 11:43 AM
MT Stringer's Avatar
Read, understand, and follow the operating instructions for each power tool that you use.
Measure twice, cut once.
Cricket, Mario Laniel and ACE0220 like this.
MT Stringer is online now
post #5 of 225 (permalink) Old 02-15-2017, 12:11 PM
First Name: Darryl
Take the router out of the box (first step).Always cut end grain first. Start with a shallow setting for any router bit being used, then gradually increase the depth of cut until desired depth of cut is achieved. Material such as oak,maple (hard woods) may need a micro cut near end of desired setting to remove any burn marks that might appear. Happy routing.
Cricket and ACE0220 like this.
mcmahondl is offline
post #6 of 225 (permalink) Old 02-15-2017, 12:28 PM
Subscribe to Router Forums.com
Herb Stoops is online now
post #7 of 225 (permalink) Old 02-15-2017, 01:10 PM
boogalee's Avatar
First Name: Al
Keep your fingers away from spinning things.
kp91, SteveMI, HoweA and 3 others like this.
Al B
boogalee is offline
post #8 of 225 (permalink) Old 02-15-2017, 01:23 PM
The main difference between a novice and an expert is that an expert knows how to fix the mistakes so that they don't show. That knowledge usually comes from trying and failing and figuring out how to fix it so that you don't have to start over.
post #9 of 225 (permalink) Old 02-15-2017, 01:30 PM
First Name: Earl
As a hobbyist, I like to try a new technique on each project--keeps me moving forward, and gives me additional tools for later projects.
Safety starts with how we dress for the session--avoid loose-fitting clothing and open front shirts/vests, especially when using a power tool.
earl
ACE0220 likes this.
greenacres2 is offline
post #10 of 225 (permalink) Old 02-15-2017, 01:40 PM
BrianS's Avatar
First Name: Brian
Always practice safe woodworking practices. Safety glasses, hearing protection, push blocks, dust mask are all a must IMHO.
Brian
They say marriages are made in heaven.... but so is thunder and lightning.
Clint Eastwood.
BrianS is offline
Closed Thread
Human Verification
Triton MOF001 2-1/4 HP Dual-Mode Plunge Router bryansong Table-mounted Routing 22 05-25-2016 01:07 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
For Sale: Triton TRC001 3-1/4 HP Router oldhippie1951 Woodworking Classifieds 0 08-15-2011 01:30 PM
Triton 1/2" precision router 2400w alfredo Starting Off 0 09-21-2009 12:23 PM
Triton 3 1/4 HP plunge router $299 CDN CanuckBeaver The Bargain Bin 10 04-15-2006 10:41 AM
You may not post new threads
