Will it Clear Up? - Router Forums
 3Likes
  • 1 Post By DaninVan
  • 1 Post By Herb Stoops
  • 1 Post By honesttjohn
post #1 of 8 (permalink) Old 02-14-2017, 08:05 PM Thread Starter
Default Will it Clear Up?
Been trying to use up some of the things that have been accumulating the last 5-10-20 years or so.
Had a can of Polycrylic (darn you Minwax) so I said why not. Went on white like water based poly does, but when it dried, it stayed white in the nooks and crannys on the carving. Question -- will it clear up eventually or not. It's been about 4 days since the final coat.
HJ
Detroit Burbs
honesttjohn is offline
post #2 of 8 (permalink) Old 02-14-2017, 08:39 PM
First Name: Richard
My guess is it won't clear up. But that is only a guess, I'm hoping for you that it will.
Shop guy is offline
post #3 of 8 (permalink) Old 02-15-2017, 01:04 AM
John; I'm not clear (OK, I'll take the pun) on whether the product you're talking about is waterborne or solvent based(?).
Also, is it a Urethane or Acrylic?
If moisture gets trapped under Acrylic it can stay/turn milky until it disappears. That's been my biggest complaint against the waterborne Acrylic concrete sealers (for exposed aggregate concrete). Never had that problem with the solvent based product.
Try putting the project someplace warm with good airflow; give it a week. It'll take at least that long to cure anyway.
jj777746 likes this.
DaninVan is offline
post #4 of 8 (permalink) Old 02-15-2017, 08:00 AM
Contact MinWax????
blackemmons is offline
post #5 of 8 (permalink) Old 02-15-2017, 08:09 AM
First Name: Quenten
My bet is it will clear up. Since it dried clear on the other areas, it just needs more time. Those corners/crevices accumulate more product making it thicker & thus needs more time.
Tonto1 is offline
post #6 of 8 (permalink) Old 02-15-2017, 08:10 AM Thread Starter
Dan,
It's Minwax's water based poly. Got a quart of it a while ago. Figured I could use it up on something. Don't want it to go to waste, but I probably won't be buying any more.
HJ
Detroit Burbs
post #7 of 8 (permalink) Old 02-15-2017, 12:44 PM
Is that the 5 yr. old stuff or the 20 yr. old stuff?
MT Stringer likes this.
Herb Stoops is offline
post #8 of 8 (permalink) Old 02-15-2017, 04:58 PM Thread Starter
Probably around 10 - but was a brand new sealed can.
Herb Stoops likes this.
HJ
Detroit Burbs
Human Verification
Clear Plastic Chip Shield Importance and Options pgtr General Routing 9 07-17-2014 08:10 AM
Clear 'void filler' for tabletop matt1710 The Finishing Touch 17 09-19-2011 11:16 AM
wipe on stain clear coat more stain (layers) tiggol The Finishing Touch 6 03-22-2010 10:35 AM
clear base plate for Ryobi router Sleighbor General Routing 16 02-01-2010 04:49 PM
