. Making a CD Tower and
. Finishing - or Not Finishing - Vintage and Distressed Wood
Hi Folks,
Thanks to everyone for supporting this wonderful site. This is my first post. It seems appropriate as I recently made a CD case with very old and funky wood.
When we moved in 14 years ago, I found a corner of the basement that occasionally got wet. It had a couple of 11" wide 7' long 1/2" thick pine boards serving as gangways over the occasional puddles.
The boards had a thin, unvarnished coat of walnut stain and had cleats nailed across the face every few feet to keep it dry, but many years of damp and basement had left these boards looking like a good candidate for the bon fire.
They were, however, 11" wide antique boards, a treasure not to squander.
I decided to make a distressed looking CD case and did everything to preserve the patina and scars of a long life.
I pulled the nails and cleats, scanned for metal and then, sanded the surface - which had calcite deposits from the water and concrete of the basement - not with sandpaper, but with 120 grit Drywall and Plaster Sanding Screens in an orbital palm sander (they're like screen door fabric with grit attached). That's all the prep I did as the skin on the boards has an odd yet warm resonance that blends with all the dozen or other wood pieces in the room.
I ripped the boards down the center, used an old piece of found Walnut for the top and bottom pieces, cut a back out of old masonite and put in the shelves with pocket screws.
I found from my chop saw scraps that this wood was so funky that you could bend it like rubber. I chose pocket screws as they 'suck in' the sides and all the weight on the shelves only pulls more and makes the sides tighter. The real caution with Pocket Screws is to make sure the wood is solid enough NOT to crack, split and crap when you drive the screws. I always think 'LOW TORQUE' using pocket screws - especially with distressed wood.
The CD cased turned out to be 7' tall, 2 1/2' wide with 13 shelves. It can hold all of my CDs, several shelves of knick-knacks and has room for many more years of purchases. It could eventually hold over 800 CDs as the knick-knacks are displaced. I added a simple cut scroll top made from an oddly matching red oak board and loaded it up. It has a magnificent, warm and 'friendly' feel.
I also added an odd touch to the scroll top. When I chopped the ends off, one of them had a lovely brunt logo 'SouthWest' with a branded 'S' in a circle. I hot glued it to the front of the scroll top as a reminder of where this project came from.The 'ears' of the scroll top also protrude about 3/4" from the front giving it a bit of an 'Arts and Crafts' appearance.
I've thought about some types of finish, but I think a delicate rubbing of bee's wax might be the best. Come summer when wax co-operates more, I'll try it on my scraps first and see how it works. I'll let you know. Please let me know if you have another idea.
One other note of satisfaction is that this project - including the shelves - was made with 100% found materials except for the Cabinet Screws I got a Meijers at 1/3 the price of my Home Center across the road.
Also, when I replace my camera, I'll post a photo.
I was thinking that barn board might be similar, weathered, wetted and dried. They are often coarse planed (or not planed) before installation. If you have a friend with a surface planer - or can rent one - you might run them thru at 1/32" or as little as possible to remove splintery wood and get down to a surface less parched by sun and weather.
I look forward to seeing your projects you create.
Many Blessings, and thanks to Bob and everyone else in this thread.
-gb
