Go Back   Router Forums > General Woodworking > The Finishing Touch
The Finishing Touch Everything you wanted to know from preparing the lumber to the final finish.
Thread Tools Display Modes
Old 11-01-2005, 09:56 AM   #1
boxer
Supreme Forum King
boxer's Avatar
boxer is on a distinguished road
Default Cleaning wood
Just out of curiosity, what do you feel is the best solvent (mineral spirits, acetone, etc.) for cleaning wood before finishing?
boxer is online now   Top - Reply with Quote
Old 11-01-2005, 10:17 AM   #2
jerrymayfield
Forum Geek
Could you be a little more specific. I wouldn't use acetone normally, it is very strong.
regards
Jerry
Old 11-01-2005, 12:19 PM   #3
boxer
Supreme Forum King
boxer's Avatar
I'm talking about wiping the wood clean before putting a finish on like lacquer or varnish. I have wiped the wood with a tack cloth, but it just doesn't have that "clean" feeling. So I have started wiping it down with MS before putting a finish on. I could be all alone on this one.
Old 11-01-2005, 03:09 PM   #4
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi boxer: It kind of depends on what kind of wood, and what is going to be used to stain and finish it. A wood like teak has a lot of oit in it. Before gluing I use Acetone.
It is also used before the stain goes on. If an oil based stain is to be used, I use MS.
If I am going to use water based products for the stain and finish, I will use a cloth dampened with water. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 11-01-2005, 04:28 PM   #5
boxer
Supreme Forum King
boxer's Avatar
Thanks, Woodnut65
I use mostly exotic woods. I never use stain on them. Mother Nature already took care of that. Right now, I'm making a Wenge & Curly Maple jewelry box. Neither are oily. The only oily wood I've used is Cocobolo, and I used acetone on that.
Kevin
Old 11-02-2005, 09:48 AM   #6
jerrymayfield
Forum Geek
MS wiped on before finish not only helps clean the surface but also shows how it will look with a clear topcoat. It also highlights any glue spots that haven't been completly removed(that doesn't happen to any of us). None of the finishers or woodworkers I know use tack cloths any longer. They are just dirt and dust magnets that we save in order to spread on a new project. I use ms,alcohol,naptha or what ever is handy,but never acetone. If you really want to glue oily wood, sand with a higher grit just before gluing,more effective than using acetone.
Regards
Jerry
Old 11-02-2005, 08:09 PM   #7
boxer
Supreme Forum King
boxer's Avatar
Thanks, Jerry. I'll give that a try the next time I use Cocobolo. Being as pricey as it is, I don't use it that often.
Kevin
Unknown, wet, wood Mitch12 Woodturning and Lathes 4 05-13-2008 01:48 AM
wood residential and business sign routing with mark disaverio Introductions 4 04-06-2008 11:31 PM
Framing a small piece of wood lea6141 Table-mounted Routing 9 01-26-2008 10:29 PM
Router bit burning the wood!!! rovailla General Routing 7 07-18-2007 03:15 AM
Questions about wood Pallets and moisture GoonMan Tools and Woodworking 2 07-05-2005 08:11 PM
