Go Back   Router Forums > General Woodworking > The Finishing Touch
The Finishing Touch Everything you wanted to know from preparing the lumber to the final finish.
Thread Tools Display Modes
Old 11-10-2005, 05:11 AM   #1
fibertech
Forum Geek
fibertech's Avatar
fibertech is on a distinguished road
Send a message via AIM to fibertech
Default Suggestions for Finish
I am making a game box for a Christmas gift. It is primarily Walnut that I have planed to 5/8" with a 3/4" stripe of Cherry for contrast. I am also using a Figured Maple veneer for the lid. My desire is a satin finish that is not too thick. I have a compressor but have not purchased spray guns, etc. Does anyone have suggestions for a spray can finish or wiped finish? I do not want any brush marks, etc. I will post pictures when I am finished. -Derek
fibertech is offline   Top - Reply with Quote
Old 11-10-2005, 06:32 AM   #2
GoonMan
Forum Geek
GoonMan's Avatar
First Name: Randy
GoonMan has a little shameless behaviour in the past
Hello Fibertech,
My neighbor was telling me to try mixing a light colored or natural Stain and Urethane together and lightly spray it on for a finish. I have not tried it yet but I am going to mix a little stain with the Urethane that I put on my work bench today and see how it turns out. I am brushing it on.
I have used a Satin Spray from Walmart before but if I go that route again I will buy a air brush and mix my own. You also will want to look at getting a filter to remove moisture.
Regards
Randy
PC Support Forums, Free on line virus Scan, The Parasite Fight,
Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~
GoonMan is offline   Top - Reply with Quote
Old 11-10-2005, 06:48 AM   #3
fibertech
Forum Geek
fibertech's Avatar
Thanks Randy. I am definitely going to avoid stain. The contrast of the Walnut and Cherry is too good. I have several good stores in the Seattle area. If I have a method or product in mind before I buy, it should turn out nice. -Derek
Old 11-10-2005, 08:43 AM   #4
delroy33
Supreme Forum King
delroy33's Avatar
delroy33 will become famous soon enough
Hi Fiberteck:
I use GENERAL FINNISHES which is a wipe on product. You can buy this in a Satin, LOW GLOSS or GLOSS. It is a oil & urethane wipe on.
For what you are proposing do about 5 to 6 applications letting each dry and rub the surface with oooo steelwool between applications. this will give you what you are looking for and will dry clear and no staining.
roy
start square, finish square
delroy33 is offline   Top - Reply with Quote
Old 11-10-2005, 10:05 AM   #5
jerrymayfield
Forum Geek
First of all I am not a fan of polyurethane varnish.If I were finishing your box I would pad on orange shellac, if the semi-gloss sheen isn't to your liking lower the sheen with a gray woven pad,not steel wool. Perhaps the easiest finish,that still high-lights the grain is waterlox wiping varnish. It is a phenolic varnish made with tung oil. Let us know what you choose.
Regards
Jerry
Old 11-10-2005, 11:46 PM   #6
fibertech
Forum Geek
fibertech's Avatar
I think what Jerry described last is what I am imagining. We have a walnut box (that the cremains for our dog came home in) that has an oil finish with a low lustre. I want to highlight the colours of the woods without a glassy finish. I will post the results and pictures in a couple of weeks. My time is so limited because I work 12 hour shifts through the night (for the largest wireless carrier in the U.S) and the honeydew projects come first.It should be in a couple of weeks. Thanks to all for the replies. -Derek
Air Compressor Suggestions mshaf23783 Tools and Woodworking 10 06-12-2007 09:32 AM
Forum Newbie needs suggestions Roger Pozzi Introductions 7 07-18-2006 04:30 PM
Suggestions for routing patterns. NewMontanaWorkshop General Routing 6 09-09-2005 12:42 AM
Ideas / Suggestions Mark Lobby 4 09-20-2004 08:55 PM
