Help
Go Back   Router Forums > General Woodworking > The Finishing Touch
Stain: Matching Old Polyurethane . . .
This is a discussion on Stain: Matching Old Polyurethane . . . within the The Finishing Touch forums, part of the General Woodworking category; Project: Refacing Kitchen Cabinets. Problem: Matching the new doors to the existing cabinet fronts. Wood ...
Old 02-08-2010, 03:15 PM   #1 (permalink)
dawziecat's Avatar
First Name: Terry
dawziecat is on a distinguished road
Default Stain: Matching Old Polyurethane . . .
Report Post Report This Post!
Wood is pine veneered plywood. Cabinets have been in place 30 years. I believe they were never stained . . . just finished with multiple coats of urethane. They are a deep, yellowish, honey colour now.
I have tried to match this with several minwax stains but really have not even come close.
Incidentally, the sample chips in the store displays seem wildly inaccurate. I mean Puritan Pine#218 and Natural#209 are pretty much indistinguishable in the store display. You get 'em home and try 'em . . . they are totally different, supposedly on the same wood as the sample chips.
Sanding off the many coats or urethane is not an option. Veneering the old cabinets might be . . . but I really don't want to do it.
Every teensy can of stain I try costs me $8 . . . and then has to be disposed of if it doesn't match. I am going broke and creating a hazardous waste disposal problem while building my own frustration level. it's a lose, lose, lose situation.
Has anyone found a stain to closely match 30 year old polyurethane? I am not being overly picky here . . . I can't even get close.
Terry Danks
Rural Nova Scotia(or Florida)
Nature and Wildlife Photography
http://danks.netfirms.com/home.htm
dawziecat is offline
Old 02-08-2010, 05:01 PM   #2 (permalink)
AxlMyk's Avatar
AxlMyk is a name known to allAxlMyk is a name known to all
If you use an oil based poly, they will eventually darken to a close shade as the present cabinets.
AxlMyk is offline
Old 02-09-2010, 11:58 AM   #3 (permalink)
dawziecat's Avatar
First Name: Terry
Thank-you, Mike.
Deciding that no, I have not had enough frustration yet and have a few dollars left, I tried two more stains. Minwax "Golden Pecan#245:" Another failure . . . another $8 thrown away . . . another mini can to take to recycling.
Then something a little different: Minwax Polyshades, "Stain and Urethane in 1 step" . . ."Honey Pine#410." Ahhhh . . . getting close now . . . FINALLY! This is a go. But, it is a gloss finish.
Still, I think I can get to where I need to be with this product.
Say, can you put water based urethane OVER oil base urethane? Is it wise? Or should I put a semi gloss, oil base urethane over the gloss finish?
(Actually, I've thought about this a bit since posting. While I do have the water based urethane on-hand, it would be better to put a semi gloss oil based urethane on top of the Polyshades product as it could use a little more darkening. There is just no need to tempt fate by applying water base over oil base and actually something to be gained if the oil base darkens a little with time.)
But, for future reference: Can you put water base urethane over an old oil base urethane?
Terry Danks
Water based stain Glenmore The Finishing Touch 9 03-18-2010 10:41 AM
Stain before gluing up? Julie Tools and Woodworking 7 02-10-2010 12:10 PM
Uniform Stain Color and Reducing Stain Buildup NJKlinkhammer The Finishing Touch 4 02-14-2008 09:27 AM
Mixing New Stain To Match Another Shade PJack The Finishing Touch 4 03-20-2007 12:12 PM
What color of stain for cherry Jimmy Ross Lobby 0 03-28-2005 03:18 PM
