Help
Go Back   Router Forums > General Woodworking > The Finishing Touch
Help with finishing
This is a discussion on Help with finishing within the The Finishing Touch forums, part of the General Woodworking category; What I usually use is a clean cotton cloth,or a shop paper towel,the blue ones ...
Old 01-06-2006, 09:42 AM   #11 (permalink)
Report Post Report This Post!
What I usually use is a clean cotton cloth,or a shop paper towel,the blue ones sold at the big box stores, wet with whatever solvent is handy (mineral spirit - denatured alcohol - naptha-etc. If you also do this before applying a finish it will give you an idea of what it will look like with a clear finish. This also will highlight any glue that has not be entirely removed. If its a large project first use a vacuumn cleaner with the soft brush attachment then wipe lightly with solven wet rag. Sorry if this is more info than you need.
Regards
Jerry
jerrymayfield is offline
Old 01-07-2006, 02:10 AM   #12 (permalink)
Katie is on a distinguished road
Thanks for the tips. It is very helpful. I need all the help I can get. I am very new to this and am really enjoying learning about it. It did seem like the tac cloth was was pretty full of dust after just one wipedown. I figured they were intended as a one time use. Makes for and expensive disposable. Here is a link to my picture in the Show and Tell section. http://www.routerforums.com/showthre...1238#post21238
Thanks again
Katie
Katie is offline
Old 01-07-2006, 09:38 AM   #13 (permalink)
I'm sure we are all happy to help. Enjoy making & finishing your projects.
Regards
Jerry
Old 01-07-2006, 06:54 PM   #14 (permalink)
berry's Avatar
First Name: Berry
berry is on a distinguished road
I'm not Jerry but I quit using tack cloths years ago. The old Dust Vac with a bristle end works well. If a project really needs to be spotless I've been using naptha on a clean rag. Some folks I think use mineral spirts.
One of the advantages of using naptha or mineral spirits is that if you hold it so light bounces off the surface it's easy to spot areas that need more sanding.
Berry in St Paul
berry is offline
Old 01-08-2006, 03:40 AM   #15 (permalink)
Sounds good Berry thanks.
Katie is offline
Old 06-07-2009, 05:52 AM   #16 (permalink)
infinitywood's Avatar
First Name: Patrick
infinitywood is on a distinguished road
Originally Posted by fibertech View Post
Jerry,
I would like one clarification from you. In mentioning not to use a tack cloth, which is your prefered method of removing dust? I am hesitant to use a damp cloth fearing the possibility of raising the grain. Your knowledge of the finishing process is awesome. Thanks -Derek
I have always used compressed air just be sure to get all the powder out &some stains will bleed out of the grain minwax is bad for it. I still use tack cloth like insid spots wher the dust is hard to blow out. Hope that helps.
infinitywood is offline
Prepping Walnut Burl Veneer for finishing? Nickbee The Finishing Touch 1 01-24-2008 10:24 AM
Rail Stile / Ply Panel gluing / finishing steps? Nickbee The Finishing Touch 10 12-12-2007 10:22 AM
Finishing for a sign harrysin The Finishing Touch 4 11-15-2007 02:02 PM
Looking for a book recommendation concerning finishing sig2269mm The Finishing Touch 2 11-15-2007 12:37 AM
What about finishing exotic woods? Mike The Finishing Touch 9 03-24-2007 07:11 PM
