| This is a discussion on Help with finishing within the The Finishing Touch forums, part of the General Woodworking category; Hello I am very new here and I want to say I am very impressed ... |
| | #1 (permalink) | ||
| Registered User ![]() |
Hello I am very new here and I want to say I am very impressed with all the great information here. I know very little about woodworking in general. I find it facinating and decided to jump right in. What better way to learn right. I am realizing now it would have been better to do more research up front. I built a desk for my husband and was amazed that it turned out pretty good. So we got ready to finish it and went to lowes. I bought a can of Olympic brand One Step (Gloss). It said it was a stain and polyurethane in one. We put it on and the color looks nice but, The surface is not very glossy and it is kind of scratchy. I don't want to put on any more of this stuff because I don't want it to get any darker in color. So I wondered if anyone could recomend a good clear varnish or other type of product to go on over this. I want the smoothest possible surface with no brush strokes. I really appreciate any help I can get on this. Thanks Katie | ||
| | #2 (permalink) | ||
Hi: I would sand the finish down with 220 grit sandpaper, very lightly to take off the rough spots. Clean it with a shop vac. and then use rags dampened with water to remove any dust. Then apply a clear high gloss polyurethane. If the original finish is completely dry you could use either water base poly or regular. I use foam throw away brushes, they don't leave marks. A couple of coats should do it. Woodnut65 | ||
| | #3 (permalink) | ||
A little more information please such as : what wood did you use, what sanding,if any, did you do before appling finish and after and by scratchy do you mean small nubs or bumps in the finish?. With a little more info, I'm sure we can help. Regards Jerry | ||
| | #4 (permalink) | ||
I used Birch with Oak trim. I did alot sanding with 140 grit sandpaper. I dusted off with a tac cloth. It felt very smooth beore putting on the One Step. Now it feels like little tiny bumps in the finish. I am realizing now I should have worked up to finer sanding. | ||
| | #5 (permalink) | ||
Sorry a little correction there it was 150 not 140. | ||
| | #6 (permalink) | ||
A couple of thoughts. My experience is that glossy finishes are the hardest to get right. 1. have you contacted Olympic. usually these type of products have an 800 number. 2. you might try Wood Magazine's Forum http://www.woodmagazine.com/ & follow the propts to the Forums or Fine Woodworking's http://www.taunton.com/finewoodworking/index.asp Good luck and welcome aboard. | ||
| | #7 (permalink) | ||
Thank you for the info and links everyone. I went ahead with the 220 sandpaper and the foam brushes. Thanks Woodnut. It worked great. I used a clear shellak instead of the polyurethane and I am very happy witht the results. The finer sanding really smoothed out the surface. And the shellak is nice and glossy. | ||
| | #8 (permalink) | ||
Glad to hear you are happy with your finish. Just a couple of points for the future. When sanding before finishing it is rarely,if ever, necessary to sand with a grit over 150-180. We have done many tests and it is not possible to perceive scratches smaller than those made by 180 g. Also lose the tach cloth none of the woodworkers or finishers I know use them any longer,they are just dust magnets that we keep our dirt ,grease and such in so we can spead it on our next finish. Regards Jerry | ||
| | #9 (permalink) | ||
One more thing, if you use stain and varnish USE THEM ONE AT A TIME. It may seem like a good idea to combine them, but generally turns into a finishing headache. Regards Jerry | ||
| | #10 (permalink) | ||
| Registered User ![]() Join Date: May 2005 Location: Mopunt Vernon, WA USA First Name: Derek Posts: 337 ![]() |
Jerry, I would like one clarification from you. In mentioning not to use a tack cloth, which is your prefered method of removing dust? I am hesitant to use a damp cloth fearing the possibility of raising the grain. Your knowledge of the finishing process is awesome. Thanks -Derek | ||
| Prepping Walnut Burl Veneer for finishing? | Nickbee | The Finishing Touch | 1 | 01-24-2008 10:24 AM |
| Rail Stile / Ply Panel gluing / finishing steps? | Nickbee | The Finishing Touch | 10 | 12-12-2007 10:22 AM |
| Finishing for a sign | harrysin | The Finishing Touch | 4 | 11-15-2007 02:02 PM |
| Looking for a book recommendation concerning finishing | sig2269mm | The Finishing Touch | 2 | 11-15-2007 12:37 AM |
| What about finishing exotic woods? | Mike | The Finishing Touch | 9 | 03-24-2007 07:11 PM |
