Best glue chioce for MDF - Router Forums
post #1 of 7 (permalink) Old 07-11-2006, 06:11 PM Thread Starter
Router is still my name's Avatar
I decided to make my own router tabletop.
Whats the best glue for gluing high-grade MDF boards together?
Im concerned about expansion or swelling and humidity.
Thank you
router ancora il mio nome
Router is still my name is offline
post #2 of 7 (permalink) Old 07-11-2006, 11:45 PM
You may want to use something other than MDF for the top if you have a high humidity.
Do you live down south (USA) ?
You may want to look at the highend plywood for the top.(6 to 10 layers on 3/4" thick plywood)
Gorilla Glue works best for me,little water and some Gorilla glue and it's done.
Plus it will give you some time to move it around and sq. it up b/4 you clamp it unlike the white and yellow wood glues.
Just a note**** you may want to think about using plywood,one 3/4" plywood and a top layer of 1/4" to 1/2" white or clear Plastic,(same as your router table base plate) it's flat and slick.( Smooth, glossy, and slippery)
One more note****take a look at the Oak-Park router table top (it's plywood)
"Made of baltic birch plywood for sturdy construction"
http://us.oak-park.com/catalogue.htm...ref=usa12.html
Just my 2 cents
Bj
post #3 of 7 (permalink) Old 07-12-2006, 06:28 AM
AxlMyk's Avatar
I've understood that MDF is fine, and better if it's sealed.. That's why I used it.. It gets humid here in Michigan.. It's my understanding that plywood, even high grade, isn't as flat..
AxlMyk is offline
post #4 of 7 (permalink) Old 07-12-2006, 02:55 PM Thread Starter
Thanks. Over 95% of the tops I've looked at including the one I sold are made of MDF. with the exception of CMT ( bad design) and JessEm which are UHMW but I didn't want to sell all my routers and mortgage the house...
I'm in houston, it doesn't get hoter and more humid than this not even in Louisiana. Sure miss CA...
I've always used Gorilla Glue. I guess I'll stick with that.
post #5 of 7 (permalink) Old 07-12-2006, 04:51 PM
I just built a new router table and used the CMT top because it was the best design I could find for the money ($100.oo bucks)
It's great, it can be used just like the Oak-Park and use all the fixtures they make or you can take the bits out from the top and with the swing fence you don't need to remove the fence to replace a bit plus it will let you use up to 4 1/2" dia. bits and with just a little rework you can use the P.C. brass guides, plus you can use it from the front or the back by poping out the router plate and just turn it around and drop it back in.
In this way you can use the T-track or have a wide base for wide stock.
The port hole for the router is off set from the center of the table by about 6".
And the real plus it's Industrio Phenolic Routertop with Alum.Insert Ring
http://www.sommerfeldtools.com/products.asp?ID=6
http://www.sommerfeldtools.com/closeouts.asp
List of 278.oo on sale for 99.oo
It's should last for a long time.. ,neat top....
Just a NOTE,,,some Great prices on router bits (close out specials)
do a search on the web page for bits (it will show a picture of them)
Just my 2 cents
Bj
post #6 of 7 (permalink) Old 07-12-2006, 06:48 PM Thread Starter
The best router table top is the one that suits out exact needs.
post #7 of 7 (permalink) Old 07-15-2006, 02:24 AM
Any of the Titebond glues will work fine with MDF. I use Titebond 3 the most since it has the longest working time, fastest cure time, and is water resistant.
Human Verification
Wanted: Looking for glue pot bobj3 Woodworking Classifieds 16 03-30-2009 07:46 AM
Pattern Glue BernieW Wood Scrolling 14 09-25-2008 10:16 PM
To glue or not to glue AxlMyk Project Plans and How To 3 05-04-2008 10:41 AM
Glue advice Router is still my name Tools and Woodworking 17 10-08-2006 10:18 AM
Glue berry The Finishing Touch 3 01-21-2006 10:46 AM
