Go Back   Router Forums > General Woodworking > The Finishing Touch
Rate This Thread - Finishing Cedar Dining Chairs.
Thread Tools Display Modes
Old 10-22-2006, 01:47 AM   #1
nzgeordie
Forum King
nzgeordie's Avatar
nzgeordie is on a distinguished road
Question Finishing Cedar Dining Chairs
Any advice on finishing cedar dining chairs? They are very rough open grain and I'd like to get a smoother finish to match a pair of oak carvers from the same (Dutch) manufacturer. I'm considering the old plaster of parish wash technique but is there anything better?
Pete
I've cut it twice and it's still too short! But only at one end.
nzgeordie is offline   Top - Reply with Quote
Old 10-23-2006, 01:38 AM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Geordie, This is a tough question and when in doubt I ask a professional. I will forward your question and be happy to post the reply ASAP.
Old 10-23-2006, 02:35 PM   #3
nzgeordie
Forum King
nzgeordie's Avatar
Thanks Mike. Any advice would be appreciated. I maybe should have mentioned that I plan to stain the cedar to try and match the two carvers otherwise I would have considered sanding sealer followed by lots of work with my new detail sander. Any finish would need to be able to take a stain.
Pete
Old 10-23-2006, 06:00 PM   #4
Senior Moderator
Supreme Forum King
Ok, here is the reply from my favorite expert:
A: There are two groups of woods called cedar; the common American softwoods, which are not open grained, and the so called Spanish cedar group, which are open pore hardwoods with a grain pattern similar to mahogany. If you have the former and it is rough, simply sand it. In the case of the latter, you can certainly fill the pores if you like, and plaster of Paris will work, though I must admit that in my mind, it would be far easier to use a pre-mixed pore filler from one of the companies that sells it. However, I will also point out that while it is common to fill table tops, it is quite rare to fill pores on chairs unless they are very high line or antique copies. You will find pore filler at most woodworking specialty stores and at a wealth of online vendors.
Michael Dresdner
Old 10-23-2006, 09:18 PM   #5
nzgeordie
Forum King
nzgeordie's Avatar
Cheers Mike. As these originated in Holland it's more likely to be a European cedar. Once they are stripped down I'll try sanding & staining a hidden area to see what the results are like before deciding if a pore filler is needed. Once they're stripped I'll post before / after close-ups before doing anything further.
Pete
Old 10-27-2006, 05:54 PM   #6
nzgeordie
Forum King
nzgeordie's Avatar
I'll post these pics before having the chairs stripped. The panel-back chair in oak is one I re-finished and covered. The splatter back is from the same manufacturer but in cedar. The close-up of the splatter kinda shows how rough the timber is. I'm not sure if I'll be able to get a match given that cedar is a red colour (whatever the stain is on these prevents me from seeing quite how they'll look stripped down) but I'll post another snap after stripping.
finishing-cedar-dining-chairs-chairs-001.jpg  finishing-cedar-dining-chairs-chairs-002.jpg  finishing-cedar-dining-chairs-chairs-005.jpg
Pete
Dining room chairs template tom Guide Bushings and Templates 17 02-18-2008 10:51 PM
Rail Stile / Ply Panel gluing / finishing steps? Nickbee The Finishing Touch 10 12-12-2007 10:22 AM
Finishing for a sign harrysin The Finishing Touch 4 11-15-2007 02:02 PM
finishing cedar wil141 The Finishing Touch 11 07-21-2007 09:07 AM
What about finishing exotic woods? Mike The Finishing Touch 9 03-24-2007 07:11 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
