Go Back   Router Forums > General Woodworking > The Finishing Touch
The Finishing Touch Everything you wanted to know from preparing the lumber to the final finish.
Thread Tools Display Modes
Old 09-11-2007, 10:39 AM   #1
WoodyRon
New Member
WoodyRon is on a distinguished road
Default Poly the inside of furniture?
Hi: do any of you poly the "inside" of a furniture cabinet. I just completed a bar/buffet out of oak and I did stain the inside as well as the outside as the inside has shelves and a drawer, etc. So now I'm ready to poly but I'm not sure what benefit it would have to poly the inside as well as the outside. I could see using poly on the shelves but then would the interior sides look dull if I didn't poly them? Thanks in advance for your tips.
WoodyRon is offline   Top - Reply with Quote
Old 09-11-2007, 10:52 AM   #2
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
NO... you will get into "smell" problems...
A coat of 2# cut shellac is better...
Joe Lyddon is offline   Top - Reply with Quote
Old 09-11-2007, 11:35 AM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi WoodyRon
I do but I use a spray gun to put on poly.or Clear lacquer coat like many of the Mfg.do
Once the ploy./lacquer is dry for a week or so you can't smell it..
I just about always leave the back off so the spray can flow without any runs on the back board.
Once it's dry I put the back on...and give one more coat on the outside.
Many wipe it on but I found it hard to get it in the corners...
I should note I use a HIGH VOLUME LOW PRESSURE setup less over spray...
http://www.harborfreight.com/cpi/cta...emnumber=44677
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 09-11-2007, 01:14 PM   #4
jerrymayfield
Forum Geek
If you want to finish the inside of any cabinet,I would use shellac or a water borne acrylic. A problem with spraying varnish is it stays in the air a long time and seems to get on everything.
Regards
Jerry
Old 09-11-2007, 09:28 PM   #5
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
ie... Example:
http://www.woodworkingtalk.com/showthread.php?t=1372
Routing a decorative edge on the inside of a faceframe? Woodworker 52 Portable Routing 2 01-29-2008 02:00 PM
Can you sand poly off to re-do the wood? dms21466 The Finishing Touch 3 01-06-2008 10:29 AM
Poly. Cutting Boards bobj3 Show N' Tell 4 08-18-2007 12:06 AM
poly on cedar? wil141 The Finishing Touch 5 06-18-2007 07:15 AM
Paint or Poly? -Sam- Tools and Woodworking 6 02-22-2005 04:55 PM
