Go Back   Router Forums > General Woodworking > The Finishing Touch
The Finishing Touch Everything you wanted to know from preparing the lumber to the final finish.
Thread Tools Display Modes
Old 10-09-2007, 08:45 PM   #1
JDługosz
Dedicated Member
JDługosz is on a distinguished road
Default Shellac issues
I'm a first-time shellac user. One thing I did not read about anywhere is the interaction of shellac over analine dyes. A splashed drop, for example, will form "faerie rings" as it spreads and moves the dye from the center to the perimeter. I'm having the same problem on inside corners and any wet edge in general. I've come up with some technique, but I'm dismayed that this was never discussed even though using shellac as a sealer coat is often mentioned!
So, any specific advice to be had anywhere?
--John
JDługosz is offline   Top - Reply with Quote
Old 10-09-2007, 09:26 PM   #2
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
--John
I have a section on Shellac in my website... which may help...
I don't remember anything about the subject you brought up... except that a shellac finish is easy to repair by just lightly sanding your problem area followed by wiping more shellac over the area... the shellac will disolve and blend into the old shellac finish.
http://www.woodworkstuff.net/woodidxfin.html
Joe Lyddon is offline   Top - Reply with Quote
Old 10-10-2007, 09:57 AM   #3
jerrymayfield
Forum Geek
What was the dye mixed with(the solvent) and how long was it allowed to dry. Shellac is one of the most under rated finishes around.
Regards
Jerry
Old 10-10-2007, 04:19 PM   #4
JDługosz
Dedicated Member
The dye was made with a small amount of alcohol and mostly water. It set for over two weeks before I did this.
Joe: I'm not worried about lap marks and places where the shellac is too thick. I'm worried about it messing with the dye.
Old 10-11-2007, 12:18 PM   #5
jerrymayfield
Forum Geek
It appears that the alcohol in the shellac is affecting the alcohol in the dye. In the future use dyes that are mixed with water and then use shellac to separate the dye from the top coat. Dyes with any alcohol really need to be sprayed.I'm afraid you will have to remove the finish or try to remove the bad effects and use a different top coat.
Good Luck
Jerry
Old 10-15-2007, 01:12 AM   #6
JDługosz
Dedicated Member
Jerry,
Any "analine" dye will dissolve in alcohol, regardless of what solvent was used to apply the dye. The dye solvent is all gone.
Minor Server Issues Mark RouterForums.com News & Feedback 0 07-05-2008 11:31 AM
Dewalt 625 issues and questions Greg_R General Routing 9 12-11-2007 05:16 PM
shellac question boxer The Finishing Touch 8 06-14-2006 12:00 AM
shellac jerrymayfield The Finishing Touch 20 12-17-2005 05:07 PM
Urethane over Shellac pmspirito The Finishing Touch 3 11-14-2005 10:25 AM
