| | #21 |
| Forum Contributer Supreme Forum King | Like you Geordie, I consider that I get depth to the finish, but unlike you I don't rub down until the final coat has hardened, and then it is with 0000 wire wool and wax. I shall however compare just two coats with my normal five on the same test piece so that both sections will receive the same amount of rubbing down.
__________________ Harry |
| | #22 |
| Registered User Forum Geek | You can apply as many coats as you like,but after the wood is sealed you will be wiping off most of what you apply (other than what evaporates) Regards Jerry |
| | #23 | |
| Registered User Forum Fanatic | Quote:
You're correct on what "Danish Oil" really is. Being a mix of MS, varnish and oil, if mixed with linseed oil and type of varnish, will have a tendency to get amberish with several applications. It can be mixed with pure tung oil also, which won't have an amberish tint. I found it much more advantageous to mix my own, thus controlling the mix ratios, and giving the results I'm after. It also saves a lot of money. As for the finishes marked as "something finish", tung oil is only "pure" tung oil if the can is marked "Pure Tung Oil", or 100% Tung oil. | |
| | #24 |
| Registered User Sr. Member | Harry, I've done several pieces with Olympic Danish Oil and Formby's Tung Oil and I've definitely seen build-up after 3-4 coats. So, I agree with your observations. Having said that, perhaps, Jerry is correct about a "true" danish oil. If so, if we like the natural oil finish and depth that we getting from our process, I wonder if a single coat of our Danish Oil "blends" and a clear lacquer top coat would be easier/process to the same end? TTG |
| | #25 |
| Registered User Forum Geek | The Olympic is an oil varnish, the Formby's is a thin wiping varnish made with an alkd resin neither contain any tung oil. Regards Jerry |
| | #26 |
| Registered User Sr. Member | Yes, and so is WATCO. All pretty darn similar. |
| | #27 |
| Registered User Forum Fanatic | I conclude, then, that my next step, after 2 coats of Formbys tung oil, is 2 or more coats of wipe-on poly. Would this be acceptable? Just re-finishing some boxes and a new clock. Thanks for this forum, Great stuff!! Neal |
| New Contest June 15 2007 | Bob | Forum Contests | 120 | 07-19-2007 09:45 AM |
