Go Back   Router Forums > General Woodworking > The Finishing Touch
The Finishing Touch Everything you wanted to know from preparing the lumber to the final finish.
Thread Tools Display Modes
Old 11-28-2007, 12:30 PM   #1
boxer
Supreme Forum King
boxer's Avatar
boxer is on a distinguished road
Default Danish oil
For those of you who use Danish Oil, do you go by the directions on the can? Or do you have your own schedule that works better for you? I've seen different brands have different instructions and wondered if anyone had a tried and true method they would share.
Thanks, Kevin
boxer is online now   Top - Reply with Quote
Old 11-28-2007, 01:49 PM   #2
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Flood it on the wood and let set for 20 minutes. Wipe off excess and let sit over night. Repeat once and that's it.
Great stuff!
Cheers,
Bob
Bob is online now   Top - Reply with Quote
Old 11-28-2007, 04:08 PM   #3
boxer
Supreme Forum King
boxer's Avatar
I appreciate it, Bob. Do you do any sanding between coats?
Kevin
Old 11-28-2007, 04:40 PM   #4
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
No sanding, just apply and let dry. Danish oil does not raise grain nor have bubbles like varnish products. I have gotten by with 4 hours drying time between coats if you need to push it some. Just be sure the 2nd coat dries over night or longer though.
Cheers,
Bob
Old 11-28-2007, 04:59 PM   #5
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Danish oil is not like most finishing products. It soaks into the wood rather than sit on top of it. How deep it penetrates depends on the type of wood among other things. I treated some small sample pieces of different types of wood to see how the finish would turn out. With maple and red oak the Watco danish oil I used penetrated about 1/8", on zebrawood about 3/8", so it is a good idea to test finish a small piece of waste material before applying any finish to see how it turns out.
Danish oil does not build up above the surface the way lacquer or polyurethane does, so it has little value protecting against scratches. After danish oil has dried completely you can apply a different product like poly for protection and a "deeper" finish.
Old 11-28-2007, 09:13 PM   #6
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
I pretty much do the same as Bob Noles. I like Danish oil to pop the grain and followed up with a couple coats poly rubbed out with steel wool and wax.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 11-28-2007, 09:18 PM   #7
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Kevin, most of my projects over the last seven years have been finished with Danish oil. I apply the first coat with a brush so that it gets into every nook and cranny. I leave this to harden for at least a day depending on the temperature. The next four coats I apply with a rag, and again leave a day between coats except for the last one, the longer the better to let it really harden. I don't sand between coats but after the last one I rub down with 0000 wire wool lubricated with Johnsons wax polish, this leaves a glass like surface and imparts a sort of patina giving the wood a very natural appearance. I recall discussing Danish oil with Corey some time ago and it appears that all Danish oils are not the same, Corey spoke of the one he was using as being quite watery whereas the RUSTINS brand that I use is as I would expect an oil to be.
Harry
harrysin is offline   Top - Reply with Quote
Old 11-28-2007, 11:46 PM   #8
challagan
Supreme Forum King
challagan's Avatar
Like Harry says, the Watco brand danish oil I use and the most prevalent here in the US while oily has a very thin watery consistency. It does not build up a surface film. Most danish oils don't. I suspect that what Harry is using while called a danish oil finish is actually an oil varnish finish that allows a surface film to be built up and has more solids/polymers in it.
Old 11-29-2007, 05:24 AM   #9
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Wow Corey, you are getting technical and as I am unable to agree or disagree with you I have a tin in front of me and will copy what is on the can.
In one area it saysanish oil contains tung oil and other special ingredients which penetrate deep into all types of timber, drying to a hard durable and water resistant seal. The oil primes seals and finishes all woods, incl. interior Oak, Teak, Mahogony, Pine and all veneered surfaces. It does not leave a surface film to chip or scratch. May also be used as a primer before painting or varnishing. Excellent for use on all turned work, incl. wooden handles of kitchen equipment tops of storage jars.
At the bottom end of the can it has: Contains cobolt octoate, methyl ethyl ketoxime, naptha. There is also a health warning.
I had to use a magnifying glass to read that as the letters are no more than 1/32"
I hope this means more to you Corey than it does to me.
Harry
Last edited by harrysin; 11-29-2007 at 05:26 AM. Reason: A "D" on Danish was replaced with a face, but it's vanished
Old 11-29-2007, 08:16 AM   #10
challagan
Supreme Forum King
challagan's Avatar
Hi Harry, sorry I was under the impression that you were able to build up surface layers to get a floss film on top. That's whyt I was thinking that it was not a true danish oil. In the US manufacturers of finish have to put very little on the can as far as ingredients. It does sound pretty much like the oil we use otherwise.
New Contest June 15 2007 Bob Forum Contests 120 07-19-2007 10:45 AM
