Help
Go Back   Router Forums > General Woodworking > The Finishing Touch
Another shellac question
This is a discussion on Another shellac question within the The Finishing Touch forums, part of the General Woodworking category; Thanks, Jerry. I bought the Zinnser 3# cut of clear shellac. I used denatured alchohol ...
Old 01-26-2008, 10:35 PM   #11 (permalink)
boxer's Avatar
boxer is on a distinguished road
Report Post Report This Post!
Thanks, Jerry. I bought the Zinnser 3# cut of clear shellac. I used denatured alchohol to cut it to 1#. The boxes I make are from a lot of exotic woods. I could never bring myself to flock the inside of a zebrawood box. As I stated before, I will go back to practicing with shellac. I just have to keep production rolling for now. I appreciate the photo diary of how you fold a rubber. I've been using cut-up pieces of t-shirt wrapped up in a square of t-shirt. Maybe that's something I need to tweak as well.
Thanks again,
Kevin
boxer is offline
Old 10-11-2008, 12:43 PM   #12 (permalink)
bobi is on a distinguished road
Can I put Helmsman spar urethane over a shellac finish
bobi is offline
Old 10-11-2008, 02:15 PM   #13 (permalink)
First Name: Bob
Bob N is a splendid one to beholdBob N is a splendid one to beholdBob N is a splendid one to behold
You betcha.... just be sure the shellc is the dewaxed type.
a/k/a "Grumpa"
Bob N is offline
Old 10-12-2008, 07:15 AM   #14 (permalink)
Timeman's Avatar
First Name: Noel
Timeman is on a distinguished road
Send a message via Skype™ to Timeman
lac bug wings !! shellac Is an old story, we in the modern day want to know what these compounds are.. If one wants to play with timber finishing and make it last
Meaning:
Once it was commonly believed that shellac was a resin obtained from the wings of an insect (order Hemiptera) found in India. In actuality, shellac is obtained from the secretion of the female insect, harvested from the bark of the trees where she deposits it to provide a sticky hold on the trunk. There is a risk that the harvesting process can scoop the insect up along with the secretion, leading to its death. The natural coloration of lac residue is greatly influenced by the sap consumed by the lac insect and the season of the harvest. Generally in the trade of seedlac there are two distinct colors: the orange Bysacki and the blonde Kushmi.
When purified, the chemical takes the form of golden yellow/ golden brown flakes, this possibly providing the basis for the "Wing Source Story." Shellac is a natural polymer and is chemically similar to synthetic polymers, thus it is considered a natural plastic. It can be turned into a moulding compound when mixed with woodflour and moulded under heat and pressure methods, so it is classified as thermoplastic. But old mouldings tend to become thermoset; that is, they suffer chemical reactions over time and are no longer fusible.
I do not use other sealers Shellac is by far the best sealer and preserver for indoors and outdoors if its waxed well.. Clean cotton sheets linen and meths and a lot of time if you want lust from your work
Is spar urethane like Polyurethane ?
Polyurethane is for boats I find on good timber and works we have done it clouds over time I mean 10 years but it just never really holds its look..
There are my tips in no way are they the right way I just put it this way after 10 years or more of playing with Exotics and common timbers.
Cheers!
Timeman is offline
Old 10-12-2008, 09:03 AM   #15 (permalink)
As I have said many times,if shellac were first used today it would be hailed as a WONDER finish.
Regards
Jerry
jerrymayfield is offline
Old 02-24-2009, 09:14 AM   #16 (permalink)
Micawber is on a distinguished road
Gidday, Just found this site. liked Jerry's suggestio0n for the rubbers. As a complete newbie I was wondering if the water marks on a table can be helped with the reactivation with meths.. If you have time Jerry maybe you can let me know.. Micawber
Micawber is offline
Old 03-11-2009, 11:29 PM   #17 (permalink)
jerryc is on a distinguished road
Sorry folks I've been out of action for the last two months. Couple of long stays in hospital. However I'm back and so can answer questions although I know jerrymayfield does an equally good trumpeting for SHELLAC-- THE WONDER FINISH.
To answer you question Micawber, Water marks on shellac can be removed. One problem with shellac however is that as it ages it gets tougher to reactivate. Not impossible, just tougher. By all means try reactivation by rubbing with meth, it will work, but be prepared to find it hard work. Since shellac is so easy to patch and repair it might even be possible to use a very light sandpaper as a last resort. I can go into that if necessay
It would be a help if you can either describe or better still post a picture of these marks. I am assuming they are white rings but more info would be useful.
Jerryc
jerryc is offline
Old 03-17-2009, 03:34 PM   #18 (permalink)
Thanks Jerry, hope all is well with you now........... The marks came out easily with the reactivation of the surface. Must be newer than I thought at first.. Regards, Micawber
Micawber is offline
Old 03-17-2009, 04:09 PM   #19 (permalink)
curiousgeorge's Avatar
First Name: George
curiousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to behold
For those interested. Here is a link to a very informative video on shellac. Charles Neil is a master woodworker but he loves to finish. He says he only builds so he has something to finish. Its the one called "Shellac: Woodworkers Best Friend"....
http://charlesneilwoodworking.com/ca...p?type=1&cat=3
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile.
curiousgeorge is offline
Old 05-24-2009, 11:38 PM   #20 (permalink)
GBM
GBM is on a distinguished road
I highly recommend the book... which many consider the Bible of Wood Finishing... by Bob Flexner ... " Understanding Wood Finishing, How to Select and Apply the Right Finish" by ' American Woodworker' - Reader's Digest.
It is really a spectacular book and he too loves Shellac....
He says " Shellac is the most underrated of all finishes"...
GBM is offline
new omnijig user with a question dracjm Introductions 1 06-29-2008 02:09 PM
Shellac issues JDługosz The Finishing Touch 5 10-15-2007 12:12 AM
shellac question boxer The Finishing Touch 8 06-13-2006 11:00 PM
Question about T-Slot Bit for router table fence. ryan.s Table-mounted Routing 5 05-02-2005 05:42 PM
