| | #1 |
| Registered User Sr. Member | I'm going to be painting some mdf moldings and was wondering what primer would work best and whether there are any special considerations in painting mdf? I've never worked with mdf before and am concerned it will swell up or fall apart or do something else strange if I don't use the right stuff on it. It is an interior application and the top coat will preferably be latex paint. Thanks for your help. rstermer Last edited by rstermer; 05-16-2008 at 04:12 AM. |
| | #2 |
| Forum Contributer Supreme Forum King | Hi retermer This just my 2 cents,, I use a good Behr white latex primer , 2 coats, the 1st one will seal the wood the 2nd one will give the paint a good place to hang on to.. It drys quick and it's ready to paint in about a hour or so when I spray it on both sides .. ![]() I should note****clean up is a big deal for me,,,that's why I use water base latex primer, it drys hard as a rock....I have tried the water base shellacs and I didn't care for them..plus I hate to see brush marks in a projects after I have put in hours to get it smooth..and flat ![]() ============
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Last edited by bobj3; 05-16-2008 at 10:17 AM. |
| | #3 | |
| Registered User Sr. Member | Quote:
rstermer | |
| | #4 |
| Registered User Forum Geek | You might be better off by sealing with shellac or an oil based primer and using an oil based paint. Regards Jerry Last edited by jerrymayfield; 05-16-2008 at 08:41 AM. Reason: add oik based primer |
| | #5 | |
Thanks, rstermer | |
| | #6 |
| Registered User Forum Geek | I like to prime painted surface with Zinser Bin Sealer. It is a pigmented shellac that dries quickly, sands smooth, and has good adhesion quality. On items like pine boards, it seals the knots well and does not allow for bleed thru. Few things I might mention with this: dries fairly quickly, make sure to use in a well ventilated area (I use in ventilated area and well as use a paint respirator), product is thin in nature, DO NOT use with foam brushes. If it were me, this is the way that I would go.
__________________ It's all good till it's no good anymore. |
| | #7 |
| Registered User Forum Geek | MDF doesn't like even a small amount of water. Regards Jerry |
