| | #1 |
| Registered User Dedicated Member | i have to strip and repaint two rocking chairs ,can anyone suggest a good product for stripping the paint off.
__________________ Wil141 AKA Woodpecker!! |
| | #2 |
| Registered User Forum Geek | I have used Jasco Paint Remover. You need a great deal of space that is well ventilated. Put the gel on with a paint brush and wait for it to bubble up. Use a light abrasive to get down to bare wood after removing all of the paint. This method is several years old and may be quite outdated. -Derek |
| | #3 |
| Registered User Forum Geek | I recommend Circa 1850 Heavy Body Paint and Varnish Remover. http://www.swingpaints.com/1806.htm It is sold in most hardware type stores. Same method as Derek said above. ~Julie~ Last edited by Julie; 06-12-2008 at 07:59 AM. |
| | #4 |
| Forum Contributer Supreme Forum King | Here in Australia I use a Citrus based remover, it looks like the solvent based type and works as well but has a pleasant citrus smell
__________________ Harry |
| | #5 |
| Registered User Forum Geek | Nothing works as well as a stripper made with MC (get the one that weighs the most) This stuff needs to be used out doors and follow all safety rules. It is the best ,and the nastiest, I have ever used. Regards Jerry |
| | #6 | |
| Forum Contributer Supreme Forum King | HI wil141 The fire place works the best,, I must have 10 or 12 hanging in the garage from the rafters and 2 or 3 on the front porch ...not to say anything about the real old one in the house... ![]() Just joking on the fire place,, they all have diff. types of coating on them, it just comes down to alot of work....I have done one or two with a small auto type sand blaster and that did work well in the tight spots...but sand paper works the best for me...and my small pointed power sander... ============== Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 06-12-2008 at 10:35 AM. | |
| | #7 |
| Registered User Dedicated Member | thanks for all the suggestion's
| Framing a small piece of wood | lea6141 | Table-mounted Routing | 9 | 01-26-2008 09:29 PM |
| Router bit burning the wood!!! | rovailla | General Routing | 7 | 07-18-2007 02:15 AM |
| What is the best wood to get a clean routered end-grain? | bekandcurt | Table-mounted Routing | 17 | 07-03-2007 12:46 AM |
| Wood for Raised Panels | rh111 | Tools and Woodworking | 8 | 09-03-2005 06:43 PM |
| Questions about wood Pallets and moisture | GoonMan | Tools and Woodworking | 2 | 07-05-2005 07:11 PM |
