Go Back   Router Forums > General Woodworking > The Finishing Touch
The Finishing Touch Everything you wanted to know from preparing the lumber to the final finish.
Thread Tools Display Modes
Old 08-27-2008, 07:48 PM   #1
rstermer
Forum Fanatic
rstermer is on a distinguished road
Default finish to use over water based stain?
Are there any limitations on the type of finish I can use over wood I've stained using a water based stain?
rstermer
rstermer is offline   Top - Reply with Quote
Old 08-28-2008, 10:17 AM   #2
jerrymayfield
Forum Geek
If you are ever in doubt apply a thin coat of dewaxed shellac. I think shellac would stick to peanut butter and peanut butter to shellac.
Regards
Jerry
Old 08-28-2008, 11:37 PM   #3
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Jerry, as I'm about to use Shellac for the first time since school in about 1948, what is dewaxed shellac?
Harry
harrysin is offline   Top - Reply with Quote
Old 08-29-2008, 10:08 AM   #4
jerrymayfield
Forum Geek
Shellac naturally contains wax(this is the type I use most of the time). The ever present polyurethane varnish and now water borne finishes have trouble adhering to natural shellac, so the caveat about dewaxed.Since it has been a while since you have used shellac, try to forget all about applying varnish. Shellac is a different animal. It is an excellent finish, I really like the less refined grades. Good luck, I think you will like it.
Regards
Jerry
Old 08-29-2008, 10:55 PM   #5
rstermer
Forum Fanatic
Regards
Jerry
Thanks Jerry, Once I apply the shellac can I then apply my finish over the shellac? Excuse me for being obtuse, but finishing is the area of woodworking about hich I know the least and which gives me the most problems.
rstermer
Old 08-30-2008, 10:18 AM   #6
jerrymayfield
Forum Geek
What are you finishing and what look are you going for?. In many cases shellac doesn't need to be top coated. Finishing is a skill that is learned like others,the only mystery is the little facts the finishing companies are willing to share and the misinformation that is given out as facts by well intentioned people.
Regards
Jerry
Old 09-02-2008, 05:10 AM   #7
rstermer
Forum Fanatic
I have made a replacement top for a jewelry box and am trying to match the existing finish which is a dark red mahogony often seen on wood items imported from China. It looks like I won't need to use the water based stain as it was too brown in tone when I applied it to a test piece of the poplar I used to make the replacement top. Right now I have a coat of red mahogony on as a base. I'm going to add a second coat of the red mahogony and then finish with two coats of Bombay mahogony finish, which is a combined stain and Polyurethane finish. That combo seemed to match the existing finish on the rest of the box pretty well. Its not a finish I would select myself if I was starting from scratch, but I need to match what is already there.
rstermer
Old 09-02-2008, 04:47 PM   #8
seawolf21
Forum Fanatic
seawolf21's Avatar
First Name: Gary
seawolf21 is on a distinguished road
The waterbased stain soaks deep into the wood so you can use any topcoat. Why not use waterbased varnish? I use it all the time and the drying time is less. Outdoor projects need marine type varnish though.
Gary
seawolf21 is offline   Top - Reply with Quote
Old 09-03-2008, 10:31 AM   #9
jerrymayfield
Forum Geek
Any mixture of stain and varnish is a disaster waiting to happen. You may find it difficult to match any color using a combination of pigment stains. I have had better luck using dye stains.
Good Luck
Jerry
Old 09-03-2008, 08:36 PM   #10
rstermer
Forum Fanatic
Good Luck
Jerry
Thanks, I'm really new to woodworking and not very skilled, so it takes me a long time to do anything. I really hate it when I screw up because I've got so much time invested in the work, but I think this will be ok. I already tried out the combo on some scrap and it seems to match the existing color pretty well.
For future reference I'd like to learn more about the dye stains you mentioned. Do you have any links or other info sources you could point me toward?
Thanks,
rstermer
oil or water based polyurethane???? jer760 The Finishing Touch 1 02-07-2008 12:59 PM
outdoor finish over stain rdw The Finishing Touch 2 12-17-2006 09:58 AM
water borne finishes jerrymayfield The Finishing Touch 1 01-07-2006 08:14 PM
water stain tableleg The Finishing Touch 1 11-03-2005 09:06 PM
Stain before gluing up? Julie Tools and Woodworking 5 02-07-2005 10:19 PM
