Rate This Thread - Hitachi M12V issue.
Thread Tools Display Modes
Old 03-19-2005, 03:35 PM   #1
Warren White
Warren White is on a distinguished road
Default Hitachi M12V issue
Good day to all!
I am new to the forum, and found you doing a search for a problem that I discover some of us share. I used my new Hitachi M12V to do some dovetails (using a 1/4" bit with the collet sleeve). Well, the bit moved and of course the dovetails are ruined. I have had some suggestions regarding putting the collet sleeve in, and I will try that, but I want to use a larger shaft bit to minimize the chatter.
Two questions for the group: Hitachi advertises a 3/8" sleeve (which comes out to 9.5 mm). Can you use this for an 8 mm bit? Does anyone make an after-market collet for the Hitachi that you can buy for 1/4" and 8 mm?
Thanks for any and all advise.
Warren
Warren White is offline   Top - Reply with Quote
Old 03-19-2005, 11:56 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Warren, you have to match up bits and collets exactly. The 3/8" shank bits are specialty bits for the most part, not commonly found. You will not find an aftermarket collet, just OEM replacement's. Search through this forum and you will find lots of good advice on checking your collet and possible corrections to it.
Old 03-21-2005, 03:15 PM   #3
TomB
Jr. Member
TomB is on a distinguished road
warren
try www.trend-usa.com the american arm of trend UK.
In england trend do a number of after market collets in most sizes for most routers
TomB is offline   Top - Reply with Quote
Old 03-23-2005, 05:24 PM   #4
Warren
Jr. Member
Warren is on a distinguished road
I don't know if this is one of the pieces of advice you've already recieved but, line up the through cut on the reducer sleeve with through cut on the router collet. The only time I've ever had a bit climbon my m12v's is when I didn't align the cuts. I was lucky my hand wasn't where the spiral bit came through. Up until that time I was a little careless in hand placement and pushtool use. No longer. I now live by the motto that if anything can come loose or slip it will. And most likely at the worst probable time.
Warren is offline   Top - Reply with Quote
Old 03-23-2005, 10:03 PM   #5
jeff12002
Dedicated Member
jeff12002's Avatar
jeff12002 is on a distinguished road
Send a message via AIM to jeff12002
leigh jigs makes an 8mm adapter that slides into your 1/2" collet for about 8 or 9 dollars. It works great.
jeff12002 is offline   Top - Reply with Quote
1/4" Collet for Hitachi M12V RzzB General Routing 37 05-27-2008 08:11 AM
Setting the proper RPM on the Hitachi M12V jrs4464 General Routing 5 01-10-2007 09:34 PM
Hitachi M12V aztd Table-mounted Routing 2 07-26-2006 02:07 PM
Hitachi M12V and Bosch 1619EVS routers LBrandt Table-mounted Routing 3 06-03-2006 10:42 AM
Hitachi M12V Router Problem dcarriere Tools and Woodworking 3 12-28-2004 06:50 AM
