Thread Tools Display Modes
Old 03-22-2005, 06:00 PM   #1
zxxer12
New Member
zxxer12 is on a distinguished road
Cool Dovetail geometry
Are there any good primers on the relationships between dovetail angle, diameter and depth of cut vs material thickness, etc.
I'm getting ready to cut some dovetails and want to learn some more about the basics of the joint.
TIA
zxxer12 is offline   Top - Reply with Quote
Old 03-22-2005, 10:50 PM   #2
Dewy
Forum Fanatic
Dewy's Avatar
Dewy is on a distinguished road
The reply depends on whether you intend making hand cut dovetails or use a router to produce them.
Hand cut dovetails usually have a 7° or 8° angle depending on the material.
Dovetail cutters are usually similar angles and the fit depends on the depth you set the cutter at.
Tight fit, lower the cutter slightly.
Loose fit, raise the cutter slightly.
Dewy
support team at Paltalk voice chat program
Dewy is offline   Top - Reply with Quote
Old 03-22-2005, 10:57 PM   #3
zxxer12
New Member
What is the relationship between material thickness and bit size, same different??
Does material 3/4" thickness require minimum 3/4" long cutting section on the bit??
Does the template determine the bit angle ??
I have a Stotts and his wbsite talks about an 8 Deg. bit but what about 7 or 9 deg.??
Old 03-23-2005, 03:43 AM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Zxxer, I dont think there is per say a standard for dovetails. Many of the jigs work off similar dimensions but I think that is mostly a copycat situation. Some of the nicest looking pieces have high angles or double dovetails, spacing set to all different patterns to create unique designs. Obviously a jig is designed to work in a certain set up, with a certain combination of rules. This does not mean it wont work when you change some of the parameters, just that you will need to confirm the results are what you are looking for.
Old 03-23-2005, 02:02 PM   #5
Dewy
Forum Fanatic
Dewy's Avatar
It depends on whether you want through dovetails or half blind dovetails.
The angle is personal preverence when hand cutting dovetails.
Dewy
Old 03-23-2005, 10:56 PM   #6
jeff12002
Dedicated Member
jeff12002's Avatar
jeff12002 is on a distinguished road
Send a message via AIM to jeff12002
With regards to the stots jig, look closely at the jig. The taper on the tapered fingers is 8 degrees, just like the 8 degree bit you use with the other side of the template. A 7, or 9 degree bit with this jig, will not produce tight fitting joints.
jeff12002 is offline   Top - Reply with Quote
Old 03-24-2005, 05:40 PM   #7
Cummins92
New Member
Cummins92 is an unknown quantity at this point
Zxxer12,
Router cut dovetails are determined by available cutter angles. So, I think this begs the question, are you going to custom grind dovetail cutters or have them custom gound? Or, are you looking for visual relationships? Perhaps a design manual that talks about proportions would help. Can't help you there. I have a Craftsman Dovetail Jig where all the spacing and angles are fixed. I precut one dovetail, measure the width and angle with a dial caliper, refer to trig tables, move dovetail jig with dial caliper measurements, move router depth with dial caliper measurements, finish cut. It's worked perfectly so far. Good Luck with your search and have fun.
Cummins92 is offline   Top - Reply with Quote
Dovetail Depth of Cut Sherwood Portable Routing 5 09-15-2007 11:28 AM
Rockler dovetail jig template Mike The Bargain Bin 1 07-14-2007 10:07 PM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 06:10 PM
Issues Cutting Dovetail Dados with Table Router Gazzalodi Table-mounted Routing 21 05-02-2006 11:40 PM
dovetail spline joints reible Jigs and Fixtures 7 10-02-2004 02:50 PM
