Thread Tools Display Modes
Old 03-24-2005, 12:55 AM   #1
reible
Supreme Forum King
reible's Avatar
Default New Router my way
Hi,
I am posting this in several parts.
This is strictly FYI (for your information) and I am not interested in debate of issues related to the hows and whys. If you have questions I will try to answer them as I can.
I’ve just added a new router to my shop. Since we have a lot of new people here and we are always providing information on which router to buy… what type, fixed/plunge bases combos, that sort of thing, I will tell you how I decided on the router I got.
First a little background. I have had a router since about 1976, I got a commercial Craftsman ¼” chuck rated at 1-½ HP. I used this for a number of years mostly with the old HSS bits. (I got a table, dovetail jig and lots of other attachments within the next couple of years) When I felt I was being limited by the selection of bits and carbide bits were getting cheaper I made a move to a Porter Cable 690. This is a fixed base with both ¼” and ½” collets. While it too was rated at 1-½ HP it was a lot stronger router then the Craftsman. I got tired of dealing with not having the plunge base so I added that a short time latter and started buying ½” shank carbide bits. The biggest change during all this was the new bits… A major improvement! But the router was also a big upgrade so I became a lot more interested in routing. I was doing a lot of projects where a smaller route would work better so I added a Porter Cable laminate router. About this same time I became more interested in a larger router (more HP and variable speed to spin larger bits). I added a 3-½ HP variable speed and another table. (This router weighs in at 12.8 pounds and I leave it in the table 100% of the time). I then came across a really good deal on another Porter Cable 690 (75-anniversary model) so I bought it. Sometime around this time I noticed how Norm liked using a D-handle so I added that base to my collection. Yes I have a couple Dremal tools and rotozips but I don’t really think of them as routers….
I was happy with what I had and then I started watching the router workshop… shop envy, router envy, but I began seeing that it would only be a mater of time before I added another router. Then came this forum, I knew the more I thought about routers the more I could figure out to do with them and them more I could justify adding a new one.
OK we are to the place where I explain my choice. The first thing I did is to decide on how I wanted to use this router that is “what it would be for”. The prime use for me would be as a general router, it would free up one of the other router to be table mounted, and it would my “main” router. I guess this means that if I did not have another router this is the one I would buy.
Old 03-24-2005, 12:56 AM   #2
reible
Supreme Forum King
reible's Avatar
PART 2
Since I do have other routers and have guide bushings and other Porter Cable attachments I first started looking at them. They have some newer models then mine and have a lot of improvements. Without getting to far into this I found the price becoming prohibitive, I had set a limit of about $200 US and the kit I liked was about $70 more then this.
At this point I decide to figure out what features I really wanted and when back to ground zero to do this. I wanted lightweight, more HP, maybe something about 2 HP*, a plunge and fixed base, soft start, variable speed. Collets for both ¼” and ½” bits, the ability to use pc style guide bushing, name brand… And then there was the “feel” of the router; it had to feel good in my hands.
*(My shop is a garage and very often the drive way in front of the garage. I often have to use a drop cord to an outlet in the back of the garage for my portable tools, which ends up being a 50-foot run. I have a 14-gauge cord, which limits me to about 12 amps.)
Time to go do a little “window shopping”. Maybe that should be “computer monitor window shopping”... After looking at several models and finding they sure don’t give you a lot of the details like weights and things online I did manage to narrow my list down to a couple of models, ones that were in the price range and had features that were on my list. Again a lot of questions were unanswered at this point.
I then went to the stores and took a look at the 4 contenders. Two of them dropped off the list but another was added. Out of this short, lets call them B, P and H, I found that I like the feel of the fixed base of B but the plunge did not feel right to me. The P was to my liking but I like the feel of H best. Since the B seemed to be a popular one on the board I went to another store a few day later to see if another one would have a different feel. The store only had two of the models but the feel on the B was better… Keep this in mind when shopping, things get dropped or messed with so don’t pass judgment based on a single one in the store. I then went to a third store and did the same general things, felt the weight, grip, and switch position, plunge action, adjustments. This was beginning to get a lot harder then I first thought it was going to be.
Old 03-24-2005, 12:57 AM   #3
reible
Supreme Forum King
reible's Avatar
Part 3
I could live with any of the three, but the best feel for me was the H, so that got a check mark on that. One was rated a little lower on the HP so it got a minus for that. When I was all done the list was down to 2. At this point the price was $200 US but I had not tried to get find the “best” price yet. I will admit the H was no. 1 and the B was in second place before this started. The H won hands down on the price. The biggest negative on this was the lack or reviews as it was a new model. One more look at them, one more check on prices, and one more look for a review.
I never did find the review but then I found a second B with an issue with the plunge at yet another store. At this point the H looked like the winner but I still had to find order it and when I did I found a place with an additional $25 off. So the H with shipping tax and router was $158.??.
I ordered it, it arrived, I played with it and gave it a test spin…… it is even better then I expected with a lot of surprises, all of them good one!
Ed
Old 03-24-2005, 05:25 AM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Ed, Hopefully people new to routing will get the chance to read this and follow your example. With so many quality choices it's tough to make a decision. Spending the time to really check out which router feels the best in your hands and which features are right for you is well worth it. I had the opportunity to check out H and it seems like a sweet little machine. I still prefer the feel of my favorite in my hands, it was the best solution for my needs. Congrats on the new addition! (Are you passing out cigars? )
Old 03-24-2005, 09:00 AM   #5
reds_21
Forum Fanatic
reds_21's Avatar
reds_21 is on a distinguished road
i will definately keep this in mind when i decide to upgrade my router!!!! thank you reible!!!!!!
reds_21 is offline   Top - Reply with Quote
Old 03-24-2005, 12:28 PM   #6
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
First Name: Dave or "Doc"
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Congrats on your new purchase Ed. Hope you will enjoy it very much.
Thanks for giving your detailed discription of your selection process. It should help a newbe make a good decision.
And if you are passing out cigars, like Mike wants, I don't smoke, but I do drink! Diet Rite cola.
Dave
the "Doctor"
Dr.Zook is online now   Top - Reply with Quote
Old 03-24-2005, 08:44 PM   #7
reible
Supreme Forum King
reible's Avatar
Sorry no cigars.... for one thing it's bad for your health besides I just spend this and next months allowance.
Ed
Old 03-25-2005, 12:01 AM   #8
Senior Moderator
Supreme Forum King
Well darn! I wanted one of those yellow bubble gum cigars!
Old 12-10-2005, 10:09 PM   #9
Emmie
New Member
Emmie is on a distinguished road
Thanks so much! It's really interesting to read about the entire process. I have found reviews to be very helpful when making purchases like this, and yours has really helped me to think things through.
By the way, I prefer pink bubblegum cigars ::grin::
Emmie is offline   Top - Reply with Quote
Old 12-11-2005, 03:14 AM   #10
reible
Supreme Forum King
reible's Avatar
Did you happen to read the "review" post I did on the "H" (Hitachi km12vc)? If you are still looking at routers please read and if you have any questions let me know. I think the current good prices on this kit is $180 (US). Click the link below to see the post:
www.routerforums.com/showthread.php?t=1045
I think they are still offering the free sander??? that makes this router a very good price point to look at.
Ed
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
I think my old router nearly killed me! peacefrog General Routing 5 09-23-2007 07:11 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
